venus-os:mfd-raymarine
venus-os:mfd-raymarine [2019-11-13 11:19] – mbosma | venus-os:mfd-raymarine [2020-03-26 17:05] – [1. Introduction] mvader | ||
====== Raymarine MFD Integration ====== | ====== Raymarine MFD Integration ====== | ||
- | This manual is still being actively developed. | ||
- | The integration technology used is called [[http:// | + | This document explains how to connect to Raymarine MFDs using an Ethernet connection. |
+ | The integration technology used is called [[http:// | ||
+ | TThere is also another way to connect, which by NMEA2000. See the [[https:// | ||
The MFD integration is compatible with the Axiom, Axiom Pro and Axiom XL MFDs running on LightHouse 3. The eS & gS Series multifunction displays which have been upgraded to LightHouse 3 are **not** compatible. | The MFD integration is compatible with the Axiom, Axiom Pro and Axiom XL MFDs running on LightHouse 3. The eS & gS Series multifunction displays which have been upgraded to LightHouse 3 are **not** compatible. | ||
- | Raymarine MFDs need at least LightHouse v3.11 for compatibility. | + | Raymarine MFDs need at least LightHouse v3.11 for compatibility, which was released in November 2019. |
===== 3. Wiring ===== | ===== 3. Wiring ===== | ||
Line 24: | Line 24: | ||
* A80513 - RayNet male to RJ45 adaptor cable | * A80513 - RayNet male to RJ45 adaptor cable | ||
+ | Connecting a Axiom MFD to a network router lead ls to IP address conflicts, due to the integrated DHCP server. | ||
+ | To connect the [[https:// | ||
- | On the Victron GX Device, go to Settings → Services, and there enable MQTT. | + | On the Victron GX Device, go to Settings → Services, and there enable |
Next, go to Settings → System Setup → Scroll to the bottom → Battery measurements. And there set up what batteries you want to see on the MFD; and by what name. | Next, go to Settings → System Setup → Scroll to the bottom → Battery measurements. And there set up what batteries you want to see on the MFD; and by what name. | ||
No other settings, such as IP addresses or similar are required, since the Axiom MFDs have an integrated DHCP server. | No other settings, such as IP addresses or similar are required, since the Axiom MFDs have an integrated DHCP server. | ||
+ | ===== 5. Configuring Multiple Battery Measurements ===== | ||
- | ===== 5. Configuring Multiple Battery Monitors ===== | + | This video explains how to setup multiple battery measurements, |
{{youtube> | {{youtube> |
