venus-os:mfd-raymarine
venus-os:mfd-raymarine [2019-10-20 11:35] – [Raymarine MFD Integration] guystewart | venus-os:mfd-raymarine [2019-11-17 15:18] – [5. Configuring Multiple Battery Monitors] mvader | ||
====== Raymarine MFD Integration ====== | ====== Raymarine MFD Integration ====== | ||
- | This manual is still being actively developed. | + | ===== 1. Introduction ===== |
- | Raymarine MFDs may require a firmware update for compatibility. | + | The integration technology used is called [[http:// |
- | Exact model support, and other technical details are still to come. | + | ===== 2. Compatibility |
- | ===== Step by Step ===== | + | |
- | {{: | + | The MFD integration is compatible with the Axiom, Axiom Pro and Axiom XL MFDs running on LightHouse 3. The eS & gS Series multifunction displays which have been upgraded to LightHouse 3 are **not** compatible. |
+ | Raymarine MFDs need at least LightHouse v3.11 for compatibility, | ||
- | ===== Step by Step Video ===== | + | ===== 3. Wiring ===== |
+ | The MFD needs to be connected to the [[https:// | ||
+ | The RayNet adapters can be purchased from Raymarine: | ||
+ | * A62360 - RayNet (F) to RJ45 (M) - 1m | ||
+ | * A80151 - RayNet (F) to RJ45 (M) - 3m | ||
+ | * A80159 - RayNet (F) to RJ45 (M) - 10m | ||
+ | * A80247 - RayNet (F) to RJ45 (F) Adapter | ||
+ | * A80513 - RayNet male to RJ45 adaptor cable | ||
+ | ===== 4. Configuration ===== | ||
+ | On the Victron GX Device, go to Settings → Services, and there enable MQTT. | ||
+ | Next, go to Settings → System Setup → Scroll to the bottom → Battery measurements. And there set up what batteries you want to see on the MFD; and by what name. | ||
+ | No other settings, such as IP addresses or similar are required, since the Axiom MFDs have an integrated DHCP server. | ||
+ | ===== 5. Configuring Multiple Battery Measurements ===== | ||
+ | This video explains how to setup multiple battery measurements, | ||
+ | {{youtube> | ||
+ | {{youtube> | ||
- | {{youtube> |
