venus-os:mfd-navico
venus-os:mfd-navico [2019-03-18 23:56] – [4. Configuration] mvader | venus-os:mfd-navico [2023-06-22 19:30] (current) – Removed and linked to corresponding GX manual chapter sloges | ||
====== Navico MFD Integration ====== | ====== Navico MFD Integration ====== | ||
- | ===== 1. Introduction ===== | + | Moved to: https://www.victronenergy.com/ |
- | Navico is the overall brand behind the B&G, Simrad and Lowrance MFDs. | + | |
- | {{:venus-os:navico_compatibility.png?nolink | }} | + | |
- | The Navico device needs to be connected to the Venus-device using Ethernet. Its not possible to connect over WiFi. For the ethernet connection, a Navico adapter is required: | + | |
- | * ETHADAPT-2M 127-56 | + | |
- | ==== Venus-device settings ==== | + | |
- | - Go to Settings -> Services, and there enable MQTT. | + | |
- | - Go to Settings | + | |
- | ==== Networking ==== | + | |
- | No settings are necessary. The Venus-device and the Navico devices connect to each other using a technology called linklocal addressing. | + | |
- | It is possible to connect the a router to the same LAN; and that way provide for internet access. | + | |
- | ===== 5. Usage ===== | + | |
- | TBD add screenshots and so forth. | + |
venus-os/mfd-navico.1552949765.txt.gz · Last modified: 2019-03-18 23:56 by mvader
