venus-os:mfd-navico
venus-os:mfd-navico [2019-08-15 10:42] – replace venus-device with GX device guy_stewartvenus-os:mfd-navico [2023-06-22 17:30] (current) – Removed and linked to corresponding GX manual chapter sloges
 ====== Navico MFD Integration ====== ====== Navico MFD Integration ======
-===== 1. Introduction ===== +Moved to: https://www.victronenergy.com/media/pg/Cerbo_GX/en/marine-mfd-integration-by-app.html#UUID-d5fa693e-1c4b-ec20-be20-e0baf8803e6e
-Navico is the overall brand behind the B&G, Simrad and Lowrance MFDs. +
-===== 2. Compatibility ===== +
-Navico compatible hardware: +
-{{:venus-os:navico_compatibility.png?nolink | }} +
-Note that this feature also works on the NSS EVO2. But only limited. And its not officially supported and also there will be no new software releases made by either Victron nor Navico to fix any issues that may arise. In other words, it is not a supported configuration by Navico but the consumer can feel free to use it (if they contact Navico or Victron service, our team will tell them it is not a supported configuration). More testing and user feedback will have to show what does and what does not work on the EVO2. +
-===== 3. Wiring ===== +
-The Navico device needs to be connected to the [[venus-os:start|GX device]] using Ethernet. Its not possible to connect over WiFi. For the ethernet connection, a Navico adapter is required: +
-  * ETHADAPT-2M 127-56 +
-  * CABLE RJ45M-5F ETH ADPTR NONWATERPRF +
-===== 4. Configuration ===== +
-==== GX device settings ==== +
-   - Go to Settings -> Services, and there enable MQTT. +
-   - Go to Settings -> System Setup -> Scroll to the bottom -> Battery measurements. And there set up what batteries you want to see on the MFD; and by what name. +
-==== Networking ==== +
-No settings are necessary. The [[venus-os:start|GX device]] and the Navico devices connect to each other using a technology called linklocal addressing. +
-It is possible to connect the a router to the same LAN; and that way provide for internet access. +
-===== 5. Usage ===== +
-TBD add screenshots and so forth.+
venus-os/mfd-navico.1565865776.txt.gz · Last modified: by guy_stewart
