venus-os:mfd-navico
venus-os:mfd-navico [2020-06-25 12:25] – [7. NMEA 2000] mbosma | venus-os:mfd-navico [2021-03-15 23:53] – [7. NMEA 2000] mvader | ||
Line 25: | Line 25: | ||
* Simrad OP50 | * Simrad OP50 | ||
* B&G ZC2 | * B&G ZC2 | ||
===== 3. Wiring ===== | ===== 3. Wiring ===== | ||
Line 64: | Line 66: | ||
===== 7. NMEA 2000 ===== | ===== 7. NMEA 2000 ===== | ||
- | The MFD can also be connected to the GX device | + | The MFD can also be connected to the Victron system |
The MFD can be configured easily to display the data from the GX device. There is no need to change any instance.\\ | The MFD can be configured easily to display the data from the GX device. There is no need to change any instance.\\ | ||
Line 72: | Line 74: | ||
* 127505 - Fluid level (tanks) | * 127505 - Fluid level (tanks) | ||
* 127506 - DC Detailed Status; State-of-charge, | * 127506 - DC Detailed Status; State-of-charge, | ||
+ | * 127507 - Charger Status | ||
* 127508 - Battery Status; Voltage, Current | * 127508 - Battery Status; Voltage, Current | ||
- | * 127508 - Battery Status | ||
* 127509 - Inverter Status | * 127509 - Inverter Status | ||
* J1939 AC PGNs | * J1939 AC PGNs |
