venus-os:mfd-navico
venus-os:mfd-navico [2020-06-25 10:52] – [4. Configuration] mbosma | venus-os:mfd-navico [2020-07-17 11:50] – [2. Compatibility] mvader | ||
Line 25: | Line 25: | ||
* Simrad OP50 | * Simrad OP50 | ||
* B&G ZC2 | * B&G ZC2 | ||
===== 3. Wiring ===== | ===== 3. Wiring ===== | ||
Line 71: | Line 73: | ||
The following Victron related PGNs are supported: | The following Victron related PGNs are supported: | ||
* 127505 - Fluid level (tanks) | * 127505 - Fluid level (tanks) | ||
- | * 127506 - DC Detailed Status | + | * 127506 - DC Detailed Status; State-of-charge, |
* 127507 - Charger Status | * 127507 - Charger Status | ||
- | * 127508 - Battery Status | + | * 127508 - Battery Status; Voltage, Current |
* 127509 - Inverter Status | * 127509 - Inverter Status | ||
* J1939 AC PGNs | * J1939 AC PGNs | ||
===== 8. Troubleshooting ===== | ===== 8. Troubleshooting ===== | ||
