venus-os:mfd-navico
venus-os:mfd-navico [2020-01-10 09:29] – [2. Compatibility] mbosma | venus-os:mfd-navico [2020-03-26 17:05] – [1. Introduction] mvader | ||
Line 4: | Line 4: | ||
Navico is the overall brand behind the B&G, Simrad and Lowrance MFDs. | Navico is the overall brand behind the B&G, Simrad and Lowrance MFDs. | ||
+ | This document explains how to connect to Navico MFDs using an Ethernet connection. | ||
+ | The integration technology used is called [[http:// | ||
+ | There is also another way to connect, which by NMEA2000. See the [[https:// | ||
Line 28: | Line 33: | ||
- | On the Victron GX Device, go to Settings -> Services, and there enable MQTT. | + | On the Victron GX Device, go to Settings -> Services, and there enable |
Next, go to Settings -> System Setup -> Scroll to the bottom -> Battery measurements. And there set up what batteries you want to see on the MFD; and by what name. | Next, go to Settings -> System Setup -> Scroll to the bottom -> Battery measurements. And there set up what batteries you want to see on the MFD; and by what name. | ||
Line 48: | Line 53: | ||
+ | ===== 7. Troubleshooting ===== | ||
+ | Q1: The MFD page shows outdated information or shows the connection issue page, but the GX device is running and connected and the Victron icon is present on the home page.\\ | ||
+ | A1: Try reloading the page by pressing the menu on the top right corner and select HOME. | ||
