venus-os:mfd-navico
venus-os:mfd-navico [2019-10-18 10:40] – [Networking] mvader | venus-os:mfd-navico [2021-03-15 23:53] – [7. NMEA 2000] mvader | ||
Line 4: | Line 4: | ||
Navico is the overall brand behind the B&G, Simrad and Lowrance MFDs. | Navico is the overall brand behind the B&G, Simrad and Lowrance MFDs. | ||
+ | This document explains how to connect to Navico MFDs using an Ethernet connection. | ||
+ | The integration technology used is called [[http:// | ||
Line 12: | Line 19: | ||
Note that this feature also works on the NSS EVO2. But only limited. And its not officially supported and also there will be no new software releases made by either Victron nor Navico to fix any issues that may arise. In other words, it is not a supported configuration by Navico but the consumer can feel free to use it (if they contact Navico or Victron service, our team will tell them it is not a supported configuration). More testing and user feedback will have to show what does and what does not work on the EVO2. | Note that this feature also works on the NSS EVO2. But only limited. And its not officially supported and also there will be no new software releases made by either Victron nor Navico to fix any issues that may arise. In other words, it is not a supported configuration by Navico but the consumer can feel free to use it (if they contact Navico or Victron service, our team will tell them it is not a supported configuration). More testing and user feedback will have to show what does and what does not work on the EVO2. | ||
+ | At this moment it is not possible to control the Victron MFD App other than the touchscreen.\\ | ||
+ | This means that you cannot use | ||
+ | * Local controls, i.e. WheelKey and arrow keys | ||
+ | * Simrad OP50 | ||
+ | * B&G ZC2 | ||
===== 3. Wiring ===== | ===== 3. Wiring ===== | ||
Line 21: | Line 36: | ||
+ | On the Victron GX Device, go to //Settings -> Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)// | ||
- | On the Victron GX Device, go to Settings | + | {{:venus-os: |
- | Next, go to Settings -> System Setup -> Scroll to the bottom -> Battery measurements. And there set up what batteries you want to see on the MFD; and by what name. | + | Next, go to //Settings -> System Setup -> Scroll to the bottom -> Marine MFD App configuration// |
No other settings, such as IP addresses or similar are required. The [[venus-os: | No other settings, such as IP addresses or similar are required. The [[venus-os: | ||
- | It is possible to connect the a router to the same LAN; and that way connect the GX Device to the internet. | + | It is possible to connect the a router to the same LAN; and that way connect the GX Device to the internet. |
+ | Note that the [[https:// | ||
+ | ===== 5. Configuring Multiple Battery Monitors ===== | ||
+ | {{youtube> | ||
+ | ===== 6. Step by step ===== | ||
+ | The MFD can also be connected to the Victron system using NMEA 2000, see the [[ve.can: | ||
+ | The MFD can be configured easily to display the data from the GX device. There is no need to change any instance.\\ | ||
+ | To setup the data sources on the MFD, go to //Settings > Network > Sources > Advanced...// | ||
+ | * 127507 - Charger Status | ||
+ | * 127508 - Battery Status; Voltage, Current | ||
+ | * 127509 - Inverter Status | ||
+ | * J1939 AC PGNs | ||
+ | ===== 8. Troubleshooting ===== | ||
- | ===== 5. Usage ===== | + | Q1: The MFD page shows outdated information or shows the connection issue page, but the GX device is running and connected and the Victron icon is present on the home page.\\ |
+ | A1: Try reloading the page by pressing the menu on the top right corner and select HOME. | ||
- | TBD add screenshots and so forth. | + | {{: |
