venus-os:mfd-navico
venus-os:mfd-navico [2019-10-18 10:40] – [Networking] mvader | venus-os:mfd-navico [2020-01-10 09:29] – [2. Compatibility] mbosma | ||
Line 12: | Line 12: | ||
Note that this feature also works on the NSS EVO2. But only limited. And its not officially supported and also there will be no new software releases made by either Victron nor Navico to fix any issues that may arise. In other words, it is not a supported configuration by Navico but the consumer can feel free to use it (if they contact Navico or Victron service, our team will tell them it is not a supported configuration). More testing and user feedback will have to show what does and what does not work on the EVO2. | Note that this feature also works on the NSS EVO2. But only limited. And its not officially supported and also there will be no new software releases made by either Victron nor Navico to fix any issues that may arise. In other words, it is not a supported configuration by Navico but the consumer can feel free to use it (if they contact Navico or Victron service, our team will tell them it is not a supported configuration). More testing and user feedback will have to show what does and what does not work on the EVO2. | ||
+ | At this moment it is not possible to control the Victron MFD App other than the touchscreen.\\ | ||
+ | This means that you cannot use | ||
+ | * Local controls, i.e. WheelKey and arrow keys | ||
+ | * Simrad OP50 | ||
+ | * B&G ZC2 | ||
===== 3. Wiring ===== | ===== 3. Wiring ===== | ||
Line 30: | Line 36: | ||
It is possible to connect the a router to the same LAN; and that way connect the GX Device to the internet. | It is possible to connect the a router to the same LAN; and that way connect the GX Device to the internet. | ||
- | ===== 5. Usage ===== | + | ===== 5. Configuring Multiple Battery Monitors ===== |
+ | {{youtube> | ||
+ | ===== 6. Step by step ===== | ||
- | TBD add screenshots and so forth. | + | {{: |
