venus-os:mfd-navico
Next revisionBoth sides next revision | |||
venus-os:mfd-navico [2019-03-18 23:53] – created mvader | venus-os:mfd-navico [2019-03-18 23:56] – [4. Configuration] mvader | ||
- | Navico is behind the B&G, Simrad and Lowrance | + | Navico is the overall brand behind the B&G, Simrad and Lowrance |
===== 3. Wiring ===== | ===== 3. Wiring ===== | ||
Line 17: | Line 19: | ||
- | === Venus-device settings === | + | ==== Venus-device settings |
- Go to Settings -> Services, and there enable MQTT. | - Go to Settings -> Services, and there enable MQTT. | ||
- Go to Settings -> System Setup -> Scroll to the bottom -> Battery measurements. And there set up what batteries you want to see on the MFD; and by what name. | - Go to Settings -> System Setup -> Scroll to the bottom -> Battery measurements. And there set up what batteries you want to see on the MFD; and by what name. | ||
- | === Networking === | + | ==== Networking |
No settings are necessary. The Venus-device and the Navico devices connect to each other using a technology called linklocal addressing. | No settings are necessary. The Venus-device and the Navico devices connect to each other using a technology called linklocal addressing. | ||
