venus-os:mfd-garmin
| venus-os:mfd-garmin [2020-06-25 10:26] – mbosma | venus-os:mfd-garmin [2023-06-22 17:35] (current) – sloges | ||
| Line 1: | Line 1: | ||
| - | ====== Garmin | + | ====== Garmin MFD Integration ====== |
| - | ===== 1. Introduction ===== | + | |
| - | This document explains how to connect to Garmin MFDs using an Ethernet connection. | + | |
| - | The integration technology used is called [[https:// | + | |
| - | Make sure to also study the [[https:// | + | |
| - | Note that there is an alternative method to connect, which is NMEA2000. See the [[https:// | + | |
| - | ===== 2. Compatibility ===== | + | |
| - | OneHelm is currently available for the following models: | + | |
| - | * GPSMAP® 8400/8600 MFD series | + | |
| - | * GPSMAP® 722/ | + | |
| - | Also, Active Captain is supported. This screenshot shows ActiveCaptain, | + | |
| - | ===== 3. Wiring ===== | + | |
| - | The Garmin needs to be connected to the [[https:// | + | |
| - | * Marine Network Cables - 6ft - PART NUMBER 010-10550-00 | + | |
| - | * Marine Network Cables - 20ft - PART NUMBER 010-10551-00 | + | |
| - | * Marine Network Cables - 40ft - PART NUMBER 010-10552-00 | + | |
| - | * Marine Network Cables - 500ft - PART NUMBER 010-10647-01 | + | |
| - | ===== 4. Configuration ===== | + | |
| - | ==== 4.1. GX device settings ==== | + | |
| - | - Go to //Settings -> Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)// | + | |
| - | - Go to //Settings -> System Setup -> Scroll to the bottom -> Marine MFD App configuration// | + | |
| - | - For boats; and other applications with DC loads such as lighting and a Battery Monitor installed, make sure to enable the "Has DC system setting" | + | |
| - | ==== 4.2. Networking ==== | + | |
| - | No special networking settings are necessary. Not on the Garmin; and not on the Victron GX Device. | + | |
| - | The Garmin MFDs run a DHCP server; and the [[https:// | + | |
| - | To connect the GX Device to the internet and the [[https:// | + | |
| - | :!: Connecting a Garmin MFD to a network router over Ethernet leads to IP address conflicts, due to the integrated DHCP server. | + | |
| - | :!: It is not possible to use a [[https:// | + | |
| - | ===== 5. Configuring Multiple Battery Monitors ===== | + | |
| - | {{youtube> | + | |
| - | ===== 6. Step by Step ===== | + | |
| - | ===== 7. NMEA 2000 ===== | + | |
| - | The MFD can also be connected to the GX device using NMEA 2000, see [[https:// | + | |
| - | The MFD can be configured easily to display the data from the GX device. There is no need to change any instance.\\ | + | |
| - | To setup NMEA 2000 on the MFD, go to //Settings > Communications > NMEA 2000 Setup > Device List//. Here you can view information about the connected products and change their names. Note that the names are stored on the MFD and not on the NMEA 2000 device. | + | |
| - | The following Victron related PGNs are supported: | + | |
| - | * 127505 - Fluid level (tanks) | + | |
| - | * 127506 - DC Detailed Status; State-of-charge, | + | |
| - | * 127508 - Battery Status; Voltage, current | + | |
| - | The supported PGNs may vary per model. Please consult the manual of the MFD for a list of supported PGNs. | + | |
| + | Moved to: https:// | ||
venus-os/mfd-garmin.1593080789.txt.gz · Last modified: by mbosma
