venus-os:mfd-garmin
venus-os:mfd-garmin [2019-11-21 13:06] – [2. Compatibility] mbosmavenus-os:mfd-garmin [2023-06-22 17:35] (current) – sloges
-====== Garmin MFD integration ====== +====== Garmin MFD Integration ======
-Preliminary manual +
-The integration technology used is called [[https://www.garmin.com/en-US/onehelm|Garmin OneHelm]]. +
-===== 2. Compatibility ===== +
-OneHelm is currently available for the following models: +
-  * GPSMAP® 8400/8600 MFD series +
-  * GPSMAP® 722/922/1222 Plus MFD series +
-Also, Active Captain is supported. This screenshot shows ActiveCaptain, with the Victron App: +
-{{:venus-os:garmin_gx.jpeg?nolink&800|}} +
-===== 3. Wiring ===== +
-The Garmin needs to be connected to the [[https://www.victronenergy.com/live/venus-os:start|GX device ]] using Ethernet. Its not possible to connect over WiFi. For the ethernet connection, a Garmin adapter is required: +
-  * Marine Network Cables - 6ft - PART NUMBER 010-10550-00 +
-  * Marine Network Cables - 20ft - PART NUMBER 010-10551-00 +
-  * Marine Network Cables - 40ft - PART NUMBER 010-10552-00 +
-  * Marine Network Cables - 500ft - PART NUMBER 010-10647-01 +
-===== 4. Configuration ===== +
-==== 4.1. GX device settings ==== +
-  - Go to Settings -> Services, and there enable MQTT. +
-  - Go to Settings -> System Setup -> Scroll to the bottom -> Battery measurements. And there set up what batteries you want to see on the MFD, and by what name. Make sure to check out [[https://www.dropbox.com/s/nlvqttx320zyaba/Battery%20Measurements.mov?dl=0|this video, which shows how to configure the batteries to be visible on the MFD]] +
-  - For boats; and other applications with DC loads such as lighting and a Battery Monitor installed, make sure to enable the "Has DC system setting". For more information about it; see the [[https://www.victronenergy.com/live/ccgx:start|GX Manual]]. +
-==== 4.2. Networking ==== +
-No special networking settings are necessary. Not on the Garmin; and not on the Victron GX Device. +
-The Garmin MFDs run a DHCP server; and the [[https://www.victronenergy.com/live/ccgx:start|GX device]] are by default configured to use DHCP. After plugging in the cable, the Victron icon will show up after 10 to 30 seconds. +
-To connect the GX Device to the internet and the [[https://vrm.victronenergy.com|VRM Portal]], while its Ethernet port is already in use to connect to the Garmin, use either WiFi or a GX GSM. [[https://www.victronenergy.com/​live/​ccgx:​start#​internet_connectivity|more information]]. +
-===== 5. Configuring Multiple Battery Monitors ===== +
-{{youtube>0Mrk5Q4izvg}} +
-===== 6. Step by Step ===== +
-{{:venus-os:garmin-gx_1.jpg?nolink|}} +
-{{:venus-os:garmin-gx_2.jpg?nolink|}} +
-{{:venus-os:garmin-gx_3.jpg?nolink|}} +
-{{:venus-os:garmin-gx_4.jpg?nolink|}} +
-{{:venus-os:garmin-gx_5.jpg?nolink|}} +
-{{:venus-os:garmin-gx_6.jpg?nolink|}} +
 +Moved to: https://www.victronenergy.com/media/pg/Cerbo_GX/en/marine-mfd-integration-by-app.html#UUID-1cf0fd18-cd34-92e7-6f08-cfec8fad0eca
venus-os/mfd-garmin.1574341585.txt.gz · Last modified: by mbosma
