Both sides previous revisionPrevious revisionNext revision | Previous revisionLast revisionBoth sides next revision |
venus-os:mfd-garmin [2021-03-15 23:52] – [7. NMEA 2000] mvader | venus-os:mfd-garmin [2022-05-25 15:51] – [4.2. Networking] Fixed CCGX link stefanie |
- Go to //Settings -> Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)//.{{:venus-os:venus-html5-mqtt.png?400|}} | - Go to //Settings -> Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)//.{{:venus-os:venus-html5-mqtt.png?400|}} |
- Go to //Settings -> System Setup -> Scroll to the bottom -> Marine MFD App configuration//. And there set up what batteries you want to see on the MFD, and by what name. Make sure to check out [[https://www.dropbox.com/s/nlvqttx320zyaba/Battery%20Measurements.mov?dl=0|this video, which shows how to configure the batteries to be visible on the MFD]]. {{:venus-os:venus-html5-batteries1.png?400|}}{{:venus-os:venus-html5-batteries2.png?400|}} | - Go to Menu → Settings → System Setup → Battery Measurements. And there set up what batteries you want to see on the MFD, and by what name. Make sure to check out [[https://www.dropbox.com/s/nlvqttx320zyaba/Battery%20Measurements.mov?dl=0|this video, which shows how to configure the batteries to be visible on the MFD]]. {{:venus-os:venus-html5-batteries1.png?400|}}{{:venus-os:venus-html5-batteries2.png?400|}} |
- For boats; and other applications with DC loads such as lighting and a Battery Monitor installed, make sure to enable the "Has DC system setting". For more information about it; see the [[https://www.victronenergy.com/live/ccgx:start|GX Manual]]. | - For boats; and other applications with DC loads such as lighting and a Battery Monitor installed, make sure to enable the "Has DC system setting". For more information about it; see the [[https://www.victronenergy.com/live/ccgx:start|GX Manual]]. |
The Garmin MFDs run a DHCP server; and the [[https://www.victronenergy.com/live/ccgx:start|GX device]] are by default configured to use DHCP. After plugging in the cable, the Victron icon will show up after 10 to 30 seconds. | The Garmin MFDs run a DHCP server; and the [[https://www.victronenergy.com/live/ccgx:start|GX device]] are by default configured to use DHCP. After plugging in the cable, the Victron icon will show up after 10 to 30 seconds. |
To connect the GX Device to the internet and the [[https://vrm.victronenergy.com|VRM Portal]], while its Ethernet port is already in use to connect to the Garmin, use WiFi. [[https://www.victronenergy.com/live/ccgx:start#internet_connectivity|more information]]. | To connect the GX Device to the internet and the [[https://vrm.victronenergy.com|VRM Portal]], while its Ethernet port is already in use to connect to the Garmin, use WiFi. [[https://www.victronenergy.com/media/pg/CCGX/en/internet-connectivity.html|More information]]. |
:!: Connecting a Garmin MFD to a network router over Ethernet leads to IP address conflicts, due to the integrated DHCP server. | :!: Connecting a Garmin MFD to a network router over Ethernet leads to IP address conflicts, due to the integrated DHCP server. |
