venus-os:mfd-garmin
venus-os:mfd-garmin [2021-03-15 23:52] – [7. NMEA 2000] mvader | venus-os:mfd-garmin [2021-07-30 00:46] – [4.1. GX device settings] guystewart | ||
Line 38: | Line 38: | ||
- Go to //Settings -> Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)// | - Go to //Settings -> Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)// | ||
- | - Go to //Settings | + | - Go to Menu → Settings |
- For boats; and other applications with DC loads such as lighting and a Battery Monitor installed, make sure to enable the "Has DC system setting" | - For boats; and other applications with DC loads such as lighting and a Battery Monitor installed, make sure to enable the "Has DC system setting" | ||
