venus-os:mfd-garmin
venus-os:mfd-garmin [2020-06-22 09:27] – [4.2. Networking] mbosma | venus-os:mfd-garmin [2022-05-25 15:51] – [4.2. Networking] Fixed CCGX link stefanie | ||
Line 17: | Line 17: | ||
* GPSMAP® 722/ | * GPSMAP® 722/ | ||
- | Also, Active Captain is supported. | + | Also, Active Captain is supported. |
Line 36: | Line 38: | ||
- Go to //Settings -> Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)// | - Go to //Settings -> Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)// | ||
- | - Go to //Settings | + | - Go to Menu → Settings |
- For boats; and other applications with DC loads such as lighting and a Battery Monitor installed, make sure to enable the "Has DC system setting" | - For boats; and other applications with DC loads such as lighting and a Battery Monitor installed, make sure to enable the "Has DC system setting" | ||
Line 44: | Line 46: | ||
The Garmin MFDs run a DHCP server; and the [[https:// | The Garmin MFDs run a DHCP server; and the [[https:// | ||
- | To connect the GX Device to the internet and the [[https:// | + | To connect the GX Device to the internet and the [[https:// |
:!: Connecting a Garmin MFD to a network router over Ethernet leads to IP address conflicts, due to the integrated DHCP server. | :!: Connecting a Garmin MFD to a network router over Ethernet leads to IP address conflicts, due to the integrated DHCP server. | ||
Line 53: | Line 55: | ||
{{youtube> | {{youtube> | ||
===== 6. Step by Step ===== | ===== 6. Step by Step ===== | ||
Line 63: | Line 64: | ||
+ | The MFD can also be connected to the Victron system using NMEA 2000, see the [[ve.can: | ||
+ | The MFD can be configured easily to display the data from the GX device. There is no need to change any instance.\\ | ||
+ | To setup NMEA 2000 on the MFD, go to //Settings > Communications > NMEA 2000 Setup > Device List//. Here you can view information about the connected products and change their names. Note that the names are stored on the MFD and not on the NMEA 2000 device. | ||
+ | * 127508 - Battery Status; Voltage, current | ||
+ | The supported PGNs may vary per model. Please consult the manual of the MFD for a list of supported PGNs. | ||
