venus-os:mfd-garmin
venus-os:mfd-garmin [2020-06-11 17:29] – [4.1. GX device settings] mbosma | venus-os:mfd-garmin [2021-03-15 23:52] – [7. NMEA 2000] mvader | ||
Line 17: | Line 17: | ||
* GPSMAP® 722/ | * GPSMAP® 722/ | ||
- | Also, Active Captain is supported. | + | Also, Active Captain is supported. |
Line 29: | Line 31: | ||
* Marine Network Cables - 40ft - PART NUMBER 010-10552-00 | * Marine Network Cables - 40ft - PART NUMBER 010-10552-00 | ||
* Marine Network Cables - 500ft - PART NUMBER 010-10647-01 | * Marine Network Cables - 500ft - PART NUMBER 010-10647-01 | ||
Line 43: | Line 46: | ||
The Garmin MFDs run a DHCP server; and the [[https:// | The Garmin MFDs run a DHCP server; and the [[https:// | ||
- | To connect the GX Device to the internet and the [[https:// | + | To connect the GX Device to the internet and the [[https:// |
+ | :!: Connecting a Garmin MFD to a network router over Ethernet leads to IP address conflicts, due to the integrated DHCP server. | ||
===== 5. Configuring Multiple Battery Monitors ===== | ===== 5. Configuring Multiple Battery Monitors ===== | ||
{{youtube> | {{youtube> | ||
===== 6. Step by Step ===== | ===== 6. Step by Step ===== | ||
Line 58: | Line 64: | ||
+ | The MFD can also be connected to the Victron system using NMEA 2000, see the [[ve.can: | ||
+ | The MFD can be configured easily to display the data from the GX device. There is no need to change any instance.\\ | ||
+ | To setup NMEA 2000 on the MFD, go to //Settings > Communications > NMEA 2000 Setup > Device List//. Here you can view information about the connected products and change their names. Note that the names are stored on the MFD and not on the NMEA 2000 device. | ||
+ | * 127508 - Battery Status; Voltage, current | ||
+ | The supported PGNs may vary per model. Please consult the manual of the MFD for a list of supported PGNs. | ||
