venus-os:mfd-garmin
venus-os:mfd-garmin [2020-03-26 17:05] – [1. Introduction] mvader | venus-os:mfd-garmin [2021-07-30 00:46] – [4.1. GX device settings] guystewart | ||
Line 7: | Line 7: | ||
The integration technology used is called [[https:// | The integration technology used is called [[https:// | ||
- | There is also another way to connect, which by NMEA2000. See the [[https:// | + | Make sure to also study the [[https:// |
+ | Note that there is an alternative method | ||
Line 15: | Line 17: | ||
* GPSMAP® 722/ | * GPSMAP® 722/ | ||
- | Also, Active Captain is supported. | + | Also, Active Captain is supported. |
Line 27: | Line 31: | ||
* Marine Network Cables - 40ft - PART NUMBER 010-10552-00 | * Marine Network Cables - 40ft - PART NUMBER 010-10552-00 | ||
* Marine Network Cables - 500ft - PART NUMBER 010-10647-01 | * Marine Network Cables - 500ft - PART NUMBER 010-10647-01 | ||
Line 32: | Line 37: | ||
==== 4.1. GX device settings ==== | ==== 4.1. GX device settings ==== | ||
- | - Go to Settings -> Services, and there enable both MQTT on LAN (SSL) and MQTT on LAN (Plaintext). | + | - Go to //Settings -> Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)//.{{: |
- | - Go to Settings | + | - Go to Menu → Settings |
- For boats; and other applications with DC loads such as lighting and a Battery Monitor installed, make sure to enable the "Has DC system setting" | - For boats; and other applications with DC loads such as lighting and a Battery Monitor installed, make sure to enable the "Has DC system setting" | ||
Line 41: | Line 46: | ||
The Garmin MFDs run a DHCP server; and the [[https:// | The Garmin MFDs run a DHCP server; and the [[https:// | ||
- | To connect the GX Device to the internet and the [[https:// | + | To connect the GX Device to the internet and the [[https:// |
+ | :!: Connecting a Garmin MFD to a network router over Ethernet leads to IP address conflicts, due to the integrated DHCP server. | ||
===== 5. Configuring Multiple Battery Monitors ===== | ===== 5. Configuring Multiple Battery Monitors ===== | ||
{{youtube> | {{youtube> | ||
===== 6. Step by Step ===== | ===== 6. Step by Step ===== | ||
Line 56: | Line 64: | ||
+ | The MFD can also be connected to the Victron system using NMEA 2000, see the [[ve.can: | ||
+ | The MFD can be configured easily to display the data from the GX device. There is no need to change any instance.\\ | ||
+ | To setup NMEA 2000 on the MFD, go to //Settings > Communications > NMEA 2000 Setup > Device List//. Here you can view information about the connected products and change their names. Note that the names are stored on the MFD and not on the NMEA 2000 device. | ||
+ | * 127508 - Battery Status; Voltage, current | ||
+ | The supported PGNs may vary per model. Please consult the manual of the MFD for a list of supported PGNs. | ||
