venus-os:mfd-garmin
venus-os:mfd-garmin [2020-03-26 17:05] – [1. Introduction] mvader | venus-os:mfd-garmin [2020-06-11 17:29] – [4.1. GX device settings] mbosma | ||
Line 7: | Line 7: | ||
The integration technology used is called [[https:// | The integration technology used is called [[https:// | ||
- | There is also another way to connect, which by NMEA2000. See the [[https:// | + | Make sure to also study the [[https:// |
+ | Note that there is an alternative method | ||
Line 32: | Line 34: | ||
==== 4.1. GX device settings ==== | ==== 4.1. GX device settings ==== | ||
- | - Go to Settings -> Services, and there enable both MQTT on LAN (SSL) and MQTT on LAN (Plaintext). | + | - Go to //Settings -> Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)//.{{: |
- | - Go to Settings -> System Setup -> Scroll to the bottom -> Battery measurements. And there set up what batteries you want to see on the MFD, and by what name. Make sure to check out [[https:// | + | - Go to //Settings -> System Setup -> Scroll to the bottom -> Marine MFD App configuration// |
- For boats; and other applications with DC loads such as lighting and a Battery Monitor installed, make sure to enable the "Has DC system setting" | - For boats; and other applications with DC loads such as lighting and a Battery Monitor installed, make sure to enable the "Has DC system setting" | ||
