venus-os:mfd-garmin
venus-os:mfd-garmin [2020-03-26 17:05] – [1. Introduction] mvader | venus-os:mfd-garmin [2020-05-01 11:10] – [1. Introduction] mvader | ||
Line 7: | Line 7: | ||
The integration technology used is called [[https:// | The integration technology used is called [[https:// | ||
- | There is also another way to connect, which by NMEA2000. See the [[https:// | + | Make sure to also study the [[https:// |
+ | Note that there is an alternative method | ||
===== 2. Compatibility ===== | ===== 2. Compatibility ===== |
