venus-os:mfd-garmin
venus-os:mfd-garmin [2020-02-25 08:45] – [4.1. GX device settings] mbosma | venus-os:mfd-garmin [2023-06-22 19:35] (current) – sloges | ||
- | ====== Garmin MFD integration | + | ====== Garmin MFD Integration |
- | The integration technology used is called [[https:// | + | |
- | OneHelm is currently available for the following models: | + | |
- | * GPSMAP® 8400/8600 MFD series | + | |
- | * GPSMAP® 722/ | + | |
- | Also, Active Captain is supported. This screenshot shows ActiveCaptain, | + | |
- | The Garmin needs to be connected to the [[https:// | + | |
- | * Marine Network Cables - 6ft - PART NUMBER 010-10550-00 | + | |
- | * Marine Network Cables - 20ft - PART NUMBER 010-10551-00 | + | |
- | * Marine Network Cables - 40ft - PART NUMBER 010-10552-00 | + | |
- | * Marine Network Cables - 500ft - PART NUMBER 010-10647-01 | + | |
- | ==== 4.1. GX device settings ==== | + | |
- | - Go to Settings -> Services, and there enable both MQTT on LAN (SSL) and MQTT on LAN (Plaintext). | + | |
- | - Go to Settings -> System Setup -> Scroll to the bottom -> Battery measurements. And there set up what batteries you want to see on the MFD, and by what name. Make sure to check out [[https:// | + | |
- | - For boats; and other applications with DC loads such as lighting and a Battery Monitor installed, make sure to enable the "Has DC system setting" | + | |
- | ==== 4.2. Networking ==== | + | |
- | No special networking settings are necessary. Not on the Garmin; and not on the Victron GX Device. | + | |
- | The Garmin MFDs run a DHCP server; and the [[https:// | + | |
- | To connect the GX Device to the internet and the [[https:// | + | |
- | {{youtube> | + | |
- | ===== 6. Step by Step ===== | + | |
+ | Moved to: https:// |
