venus-os:mfd-garmin
venus-os:mfd-garmin [2020-02-25 08:45] – [4.1. GX device settings] mbosma | venus-os:mfd-garmin [2020-05-01 11:10] – [1. Introduction] mvader | ||
Line 4: | Line 4: | ||
+ | This document explains how to connect to Garmin MFDs using an Ethernet connection. | ||
The integration technology used is called [[https:// | The integration technology used is called [[https:// | ||
===== 2. Compatibility ===== | ===== 2. Compatibility ===== |
