venus-os:mfd-garmin
venus-os:mfd-garmin [2019-11-13 09:59] – mbosma | venus-os:mfd-garmin [2020-06-25 12:26] – mbosma | ||
====== Garmin MFD integration ====== | ====== Garmin MFD integration ====== | ||
- | Preliminary manual | ||
+ | This document explains how to connect to Garmin MFDs using an Ethernet connection. | ||
The integration technology used is called [[https:// | The integration technology used is called [[https:// | ||
- | OneHelm is currently available for the GPSMAP® 8400/8600 MFD series. | + | OneHelm is currently available for the following models: |
+ | * GPSMAP® 8400/8600 MFD series | ||
+ | * GPSMAP® 722/ | ||
Also, Active Captain is supported. This screenshot shows ActiveCaptain, | Also, Active Captain is supported. This screenshot shows ActiveCaptain, | ||
Line 23: | Line 29: | ||
* Marine Network Cables - 40ft - PART NUMBER 010-10552-00 | * Marine Network Cables - 40ft - PART NUMBER 010-10552-00 | ||
* Marine Network Cables - 500ft - PART NUMBER 010-10647-01 | * Marine Network Cables - 500ft - PART NUMBER 010-10647-01 | ||
Line 28: | Line 35: | ||
==== 4.1. GX device settings ==== | ==== 4.1. GX device settings ==== | ||
- | - Go to Settings -> Services, and there enable MQTT. | + | - Go to //Settings -> Services//, and there enable |
- | - Go to Settings -> System Setup -> Scroll to the bottom -> Battery measurements. And there set up what batteries you want to see on the MFD, and by what name. Make sure to check out [[https:// | + | - Go to //Settings -> System Setup -> Scroll to the bottom -> Marine MFD App configuration// |
- For boats; and other applications with DC loads such as lighting and a Battery Monitor installed, make sure to enable the "Has DC system setting" | - For boats; and other applications with DC loads such as lighting and a Battery Monitor installed, make sure to enable the "Has DC system setting" | ||
Line 37: | Line 44: | ||
The Garmin MFDs run a DHCP server; and the [[https:// | The Garmin MFDs run a DHCP server; and the [[https:// | ||
- | To connect the GX Device to the internet and the [[https:// | + | To connect the GX Device to the internet and the [[https:// |
+ | :!: Connecting a Garmin MFD to a network router over Ethernet leads to IP address conflicts, due to the integrated DHCP server. | ||
===== 5. Configuring Multiple Battery Monitors ===== | ===== 5. Configuring Multiple Battery Monitors ===== | ||
{{youtube> | {{youtube> | ||
===== 6. Step by Step ===== | ===== 6. Step by Step ===== | ||
Line 52: | Line 62: | ||
+ | The MFD can also be connected to the GX device using NMEA 2000, see [[https:// | ||
+ | The MFD can be configured easily to display the data from the GX device. There is no need to change any instance.\\ | ||
+ | To setup NMEA 2000 on the MFD, go to //Settings > Communications > NMEA 2000 Setup > Device List//. Here you can view information about the connected products and change their names. Note that the names are stored on the MFD and not on the NMEA 2000 device. | ||
+ | * 127508 - Battery Status; Voltage, current | ||
+ | The supported PGNs may vary per model. Please consult the manual of the MFD for a list of supported PGNs. | ||
