venus-os:mfd-garmin
venus-os:mfd-garmin [2019-11-13 09:59] – mbosma | venus-os:mfd-garmin [2020-02-25 08:45] – [4.1. GX device settings] mbosma | ||
====== Garmin MFD integration ====== | ====== Garmin MFD integration ====== | ||
- | Preliminary manual | ||
Line 9: | Line 8: | ||
- | OneHelm is currently available for the GPSMAP® 8400/8600 MFD series. | + | OneHelm is currently available for the following models: |
+ | * GPSMAP® 8400/8600 MFD series | ||
+ | * GPSMAP® 722/ | ||
Also, Active Captain is supported. This screenshot shows ActiveCaptain, | Also, Active Captain is supported. This screenshot shows ActiveCaptain, | ||
Line 28: | Line 29: | ||
==== 4.1. GX device settings ==== | ==== 4.1. GX device settings ==== | ||
- | - Go to Settings -> Services, and there enable MQTT. | + | - Go to Settings -> Services, and there enable |
- Go to Settings -> System Setup -> Scroll to the bottom -> Battery measurements. And there set up what batteries you want to see on the MFD, and by what name. Make sure to check out [[https:// | - Go to Settings -> System Setup -> Scroll to the bottom -> Battery measurements. And there set up what batteries you want to see on the MFD, and by what name. Make sure to check out [[https:// | ||
- For boats; and other applications with DC loads such as lighting and a Battery Monitor installed, make sure to enable the "Has DC system setting" | - For boats; and other applications with DC loads such as lighting and a Battery Monitor installed, make sure to enable the "Has DC system setting" |
