venus-os:mfd-garmin
venus-os:mfd-garmin [2019-10-18 13:16] – [Networking] guy_stewart | venus-os:mfd-garmin [2019-11-13 09:59] – mbosma | ||
Preliminary manual | Preliminary manual | ||
- | ===== Introduction ===== | + | ===== 1. Introduction ===== |
The integration technology used is called [[https:// | The integration technology used is called [[https:// | ||
- | ===== Compatibility ===== | + | ===== 2. Compatibility ===== |
OneHelm is currently available for the GPSMAP® 8400/8600 MFD series. | OneHelm is currently available for the GPSMAP® 8400/8600 MFD series. | ||
Line 15: | Line 15: | ||
- | ===== Wiring ===== | + | ===== 3. Wiring ===== |
The Garmin needs to be connected to the [[https:// | The Garmin needs to be connected to the [[https:// | ||
Line 24: | Line 24: | ||
* Marine Network Cables - 500ft - PART NUMBER 010-10647-01 | * Marine Network Cables - 500ft - PART NUMBER 010-10647-01 | ||
- | ===== Configuration ===== | + | ===== 4. Configuration ===== |
- | ==== GX device settings ==== | + | ==== 4.1. GX device settings ==== |
- | - Ordered List Item | ||
- Go to Settings -> Services, and there enable MQTT. | - Go to Settings -> Services, and there enable MQTT. | ||
- Go to Settings -> System Setup -> Scroll to the bottom -> Battery measurements. And there set up what batteries you want to see on the MFD, and by what name. Make sure to check out [[https:// | - Go to Settings -> System Setup -> Scroll to the bottom -> Battery measurements. And there set up what batteries you want to see on the MFD, and by what name. Make sure to check out [[https:// | ||
- For boats; and other applications with DC loads such as lighting and a Battery Monitor installed, make sure to enable the "Has DC system setting" | - For boats; and other applications with DC loads such as lighting and a Battery Monitor installed, make sure to enable the "Has DC system setting" | ||
- | ==== Networking ==== | + | ==== 4.2. Networking ==== |
No special networking settings are necessary. Not on the Garmin; and not on the Victron GX Device. | No special networking settings are necessary. Not on the Garmin; and not on the Victron GX Device. | ||
The Garmin MFDs run a DHCP server; and the [[https:// | The Garmin MFDs run a DHCP server; and the [[https:// | ||
- | It is possible to connect the Garmin MFD to the Ethernet port of the GX device, and connect to the internet and VRM on the GX device by using [[https:// | + | To connect the GX Device |
- | ===== Usage ===== | + | ===== 5. Configuring Multiple Battery Monitors |
{{youtube> | {{youtube> | ||
- | TBD add screenshots and so forth. |
