venus-os:mfd-garmin
venus-os:mfd-garmin [2019-04-16 16:23] – mvader | venus-os:mfd-garmin [2021-07-30 00:46] – [4.1. GX device settings] guystewart | ||
- | moved to: https://docs.victronenergy.com/ | + | ====== Garmin MFD integration ====== |
+ | This document explains how to connect to Garmin MFDs using an Ethernet connection. | ||
+ | The integration technology used is called [[https:// | ||
+ | Make sure to also study the [[https://www.victronenergy.com/ | ||
+ | ===== 2. Compatibility ===== | ||
+ | OneHelm is currently available for the following models: | ||
+ | * GPSMAP® 8400/8600 MFD series | ||
+ | * GPSMAP® 722/ | ||
+ | Also, Active Captain is supported. Below screenshot shows ActiveCaptain, | ||
+ | {{:venus-os: | ||
+ | ===== 3. Wiring ===== | ||
+ | The Garmin needs to be connected to the [[https:// | ||
+ | * Marine Network Cables - 6ft - PART NUMBER 010-10550-00 | ||
+ | * Marine Network Cables - 20ft - PART NUMBER 010-10551-00 | ||
+ | * Marine Network Cables - 40ft - PART NUMBER 010-10552-00 | ||
+ | * Marine Network Cables - 500ft - PART NUMBER 010-10647-01 | ||
+ | ===== 4. Configuration ===== | ||
+ | ==== 4.1. GX device settings ==== | ||
+ | - Go to //Settings -> Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)// | ||
+ | - Go to Menu → Settings → System Setup → Battery Measurements. And there set up what batteries you want to see on the MFD, and by what name. Make sure to check out [[https:// | ||
+ | - For boats; and other applications with DC loads such as lighting and a Battery Monitor installed, make sure to enable the "Has DC system setting" | ||
+ | ==== 4.2. Networking ==== | ||
+ | No special networking settings are necessary. Not on the Garmin; and not on the Victron GX Device. | ||
+ | The Garmin MFDs run a DHCP server; and the [[https:// | ||
+ | To connect the GX Device to the internet and the [[https:// | ||
+ | :!: Connecting a Garmin MFD to a network router over Ethernet leads to IP address conflicts, due to the integrated DHCP server. | ||
+ | ===== 5. Configuring Multiple Battery Monitors ===== | ||
+ | {{youtube> | ||
+ | The MFD can also be connected to the Victron system using NMEA 2000, see the [[ve.can: | ||
+ | The MFD can be configured easily to display the data from the GX device. There is no need to change any instance.\\ | ||
+ | To setup NMEA 2000 on the MFD, go to //Settings > Communications > NMEA 2000 Setup > Device List//. Here you can view information about the connected products and change their names. Note that the names are stored on the MFD and not on the NMEA 2000 device. | ||
+ | * 127508 - Battery Status; Voltage, current | ||
+ | The supported PGNs may vary per model. Please consult the manual of the MFD for a list of supported PGNs. |
