venus-os:mfd-garmin
venus-os:mfd-garmin [2019-03-19 00:11] – [1. Introduction] mvader | venus-os:mfd-garmin [2019-10-18 13:23] – [Networking] mvader | ||
- | ====== Garmin MFD integration | + | ====== Garmin MFD integration ====== |
- | ===== 1. Introduction ===== | + | Preliminary manual |
- | The integration technology used is called Garmin OneHelm. | + | |
- | https:// | + | ===== Introduction ===== |
- | ===== 2. Compatibility ===== | + | The integration technology used is called [[https:// |
+ | ===== Compatibility ===== | ||
OneHelm is currently available for the GPSMAP® 8400/8600 MFD series. | OneHelm is currently available for the GPSMAP® 8400/8600 MFD series. | ||
- | ===== 3. Wiring ===== | + | Also, Active Captain is supported. This screenshot shows ActiveCaptain, |
+ | ===== Wiring | ||
+ | The Garmin needs to be connected to the [[https:// | ||
+ | * Marine Network Cables - 6ft - PART NUMBER 010-10550-00 | ||
+ | * Marine Network Cables - 20ft - PART NUMBER 010-10551-00 | ||
+ | * Marine Network Cables - 40ft - PART NUMBER 010-10552-00 | ||
+ | * Marine Network Cables - 500ft - PART NUMBER 010-10647-01 | ||
+ | ===== Configuration | ||
- | The Garmin needs to be connected | + | ==== GX device settings ==== |
+ | - Ordered List Item | ||
+ | - Go to Settings -> Services, and there enable MQTT. | ||
+ | - Go to Settings -> System Setup -> Scroll | ||
+ | - For boats; and other applications with DC loads such as lighting and a Battery Monitor installed, make sure to enable the "Has DC system setting" | ||
- | - Marine Network Cables - 6ft - PART NUMBER 010-10550-00 | + | ==== Networking ==== |
- | - Marine Network Cables - 20ft - PART NUMBER 010-10551-00 | + | No special networking settings are necessary. Not on the Garmin; and not on the Victron GX Device. |
- | - Marine Network Cables - 40ft - PART NUMBER 010-10552-00 | + | |
- | - Marine Network Cables - 500ft - PART NUMBER 010-10647-01 | + | |
- | ===== 4. Configuration ===== | + | The Garmin MFDs run a DHCP server; and the [[https:// |
- | === Venus-device settings === | + | To connect the GX Device to the internet and the [[https:// |
- | - Go to Settings -> Services, and there enable MQTT. | + | ===== Usage ===== |
- | - Go to Settings -> System Setup -> Scroll to the bottom -> Battery measurements. And there set up what batteries you want to see on the MFD; and by what name. | + | |
- | === Networking === | + | {{youtube> |
- | No settings are necessary. The Garmin MFDs run a DHCP server; and the Venus-devices are by default configured to use DHCP. After plugging in the cable, the Victron icon will show up after 10 to 30 seconds. | + | |
- | How to connect to both a Garmin and Internet? That is unclear as of now. | ||
- | ===== 5. Usage ===== | ||
TBD add screenshots and so forth. | TBD add screenshots and so forth. |
