venus-os:mfd-garmin
venus-os:mfd-garmin [2019-02-01 15:02] – created mvader | venus-os:mfd-garmin [2023-06-22 19:35] (current) – sloges | ||
- | ====== | + | ====== Garmin |
- | Wiring: no special cable is required, the Garmin is a normal Ethernet socket. use a standard RJ-45 LAN cable. For proper wiring, including pull relief; an adapter is necessary (TBD). | + | Moved to: https://www.victronenergy.com/ |
- | Networking | + | |
- | Usage | + | |
- | Screenshots | + |
