venus-os:mfd-garmin
venus-os:mfd-garmin [2019-02-01 15:02] – created mvader | venus-os:mfd-garmin [2020-06-22 09:27] – [4.2. Networking] mbosma | ||
- | ====== | + | ====== Garmin |
- | Wiring: no special cable is required, the Garmin is a normal Ethernet socket. use a standard RJ-45 LAN cable. For proper wiring, including pull relief; an adapter is necessary (TBD). | ||
- | Networking | + | This document explains how to connect to Garmin |
+ | The integration technology used is called [[https:// | ||
- | Usage | + | Note that there is an alternative method to connect, which is NMEA2000. See the [[https:// |
+ | ===== 2. Compatibility ===== | ||
+ | OneHelm is currently available for the following models: | ||
+ | * GPSMAP® 8400/8600 MFD series | ||
+ | * GPSMAP® 722/ | ||
+ | Also, Active Captain is supported. This screenshot shows ActiveCaptain, | ||
+ | ===== 3. Wiring ===== | ||
+ | The Garmin needs to be connected to the [[https:// | ||
+ | * Marine Network Cables - 6ft - PART NUMBER 010-10550-00 | ||
+ | * Marine Network Cables - 20ft - PART NUMBER 010-10551-00 | ||
+ | * Marine Network Cables - 40ft - PART NUMBER 010-10552-00 | ||
+ | * Marine Network Cables - 500ft - PART NUMBER 010-10647-01 | ||
+ | ===== 4. Configuration ===== | ||
+ | ==== 4.1. GX device settings ==== | ||
+ | - Go to //Settings -> Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)// | ||
+ | - Go to //Settings -> System Setup -> Scroll to the bottom -> Marine MFD App configuration// | ||
+ | - For boats; and other applications with DC loads such as lighting and a Battery Monitor installed, make sure to enable the "Has DC system setting" | ||
+ | ==== 4.2. Networking ==== | ||
+ | No special networking settings are necessary. Not on the Garmin; and not on the Victron GX Device. | ||
+ | The Garmin MFDs run a DHCP server; and the [[https:// | ||
+ | To connect the GX Device to the internet and the [[https:// | ||
+ | :!: Connecting a Garmin MFD to a network router over Ethernet leads to IP address conflicts, due to the integrated DHCP server. | ||
+ | ===== 5. Configuring Multiple Battery Monitors ===== | ||
+ | {{youtube> | ||
- | Screenshots |
