venus-os:mfd-furuno
venus-os:mfd-furuno [2021-07-30 00:45] – [4.2 Services configuration] guystewart | venus-os:mfd-furuno [2023-06-22 19:27] (current) – Removed and linked to corresponding GX manual chapter sloges | ||
====== Furuno MFD Integration ====== | ====== Furuno MFD Integration ====== | ||
- | ===== 1. Introduction ===== | + | Moved to: https:// |
- | This document explains how to connect to Furuno MFDs using an Ethernet connection. | + | |
- | Note that there is an alternative method to connect, which is NMEA2000. See the [[https:// | + | |
- | The MFD integration is compatible with the following Furuno MFDs: | + | |
- | * NavNet TZtouch3 TZT12F | + | |
- | * NavNet TZtouch3 TZT16F | + | |
- | * NavNet TZtouch3 TZT19F | + | |
- | * Navnet TZtouch2 TZT2BB Black box | + | |
- | NavNet TZtouch3 MFDs need at least software version v1.08. The Navnet TZtouch2 TZT2BB needs at least software version v7.01. | + | |
- | Note that the Navnet TZtouch2 TZT**L** models are **not** supported. | + | |
- | From Victron side, all GX devices (Cerbo GX, CCGX, Venus GX, and so forth) can be used and are compatible. For details on detailed product compatibility with regarding to inverter/chargers and other components, see the [[https://www.victronenergy.com/ | + | |
- | The Furuno device needs to be connected to the [[venus-os:start|GX device]] using Ethernet. Its not possible to connect over WiFi. For the Ethernet connection, a standard Ethernet cable can be used. The GX device can either be connected directly to the MFD or through a network router/ | + | |
- | ==== 4.1 Ethernet configuration ==== | + | |
- | On the Victron GX Device, make sure that the Ethernet cable is connected and go to // | + | |
- | ^ Setting | + | |
- | | IP Configuration | Manual | + | |
- | | IP address | + | |
- | | Netmask | + | |
- | | Gateway | + | |
- | | DNS server | + | |
- | {{:venus-os: | + | |
- | It is possible to connect a router to the same LAN; and that way connect the GX Device to the internet. Make sure the //Gateway// and //DNS Server// settings of the GX are set to the IP address of the router, and that the router has its LAN IP addressing configured in the same subnet. | + | |
- | :!: It is not possible to use a [[https:// | + | |
- | ==== 4.2 Services configuration ==== | + | |
- | On the Victron GX Device, go to //Settings -> Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)// | + | |
- | Next, go to Menu → Settings → System Setup → Battery Measurements. And there set up what batteries you want to see on the MFD; and by what name. | + | |
- | {{:venus-os:venus-html5-batteries2.png? | + | |
- | {{youtube> | + | |
- | ===== 6. NMEA 2000 ===== | + | |
- | The MFD can also be connected to the Victron system using NMEA 2000, see the [[ve.can: | + | |
- | This chapter documents the specifics when displaying Victron NMEA 2000 information on a Furuno MFDs. Note that this is not meant to be an extensive guide. Its the simple result of our R&D checking everything on a Furuno MFD. The functionality is (mostly) dictated by Furuno software and may therefore also change and improve when Furuno company changes their software. | + | |
- | The MFD can be configured easily to display the data from the GX device. To display tank data, there is no need to change any instance. \\ | + | |
- | In order to properly display battery/DC data from Victron equipment, you need to change the data instances of the PGNs that are sent out. See here for how to do that: [[https:// | + | |
- | To view NMEA 2000 devices on the MFD, go to //Settings > Initial Setup > Data Aquisition > Sensor List//. Here you can view basic information and change device instances and custom names. | + | |
- | The following Victron PGNs are supported: | + | |
- | * 127505 - Fluid level (tanks) | + | |
- | * 127506 - DC Detailed Status (limited support); State-of-charge, | + | |
- | * 127508 - Battery Status (limited support); Voltage, Current < | + | |
- | **Notes** | + | |
- | - The tested Furuno MFD firmware supports a maximum of 4 batteries, no more | + | |
- | - Due to a bug in the MFD firmware, a negative battery current (ie. when discharging) is shown as '' | + |
venus-os/mfd-furuno.1627598737.txt.gz · Last modified: 2021-07-30 00:45 by guystewart
