venus-os:mfd-furuno
| venus-os:mfd-furuno [2020-06-11 15:17] – [1. Introduction] mbosma | venus-os:mfd-furuno [2023-06-22 17:27] (current) – Removed and linked to corresponding GX manual chapter sloges | ||
| Line 1: | Line 1: | ||
| ====== Furuno MFD Integration ====== | ====== Furuno MFD Integration ====== | ||
| - | ===== 1. Introduction ===== | + | Moved to: https:// |
| - | This document explains how to connect to Furuno MFDs using an Ethernet connection. | + | |
| - | Make sure to also study the [[https:// | + | |
| - | Note that there is an alternative method to connect, which is NMEA2000. See the [[https:// | + | |
| - | ===== 2. Compatibility ===== | + | |
| - | The MFD integration is compatible with the following models: | + | |
| - | * NavNet TZtouch3 TZT12F | + | |
| - | * NavNet TZtouch3 TZT16F | + | |
| - | * NavNet TZtouch3 TZT19F | + | |
| - | * Navnet TZtouch2 TZT2BB Black box | + | |
| - | NavNet TZtouch3 MFDs need at least software version v1.08. The Navnet TZtouch2 TZT2BB needs at least software version v7. | + | |
| - | Note that the Navnet TZtouch2 TZT**L** models are **not** supported. | + | |
| - | ===== 3. Wiring ===== | + | |
| - | The Furuno device needs to be connected to the [[venus-os: | + | |
| - | ===== 4. Configuration ===== | + | |
| - | ==== 4.1 Ethernet configuration ==== | + | |
| - | On the Victron GX Device, make sure that the Ethernet cable is connected and go to //Settings | + | |
| - | ^ Setting | + | |
| - | | IP Configuration | Manual | + | |
| - | | IP address | + | |
| - | | Netmask | + | |
| - | | Gateway | + | |
| - | | DNS server | + | |
| - | {{:venus-os:furuno-ip-config.png? | + | |
| - | It is possible to connect a router to the same LAN; and that way connect the GX Device to the internet. Make sure the //Gateway// and //DNS Server// settings of the GX are set to the IP address of the router. | + | |
| - | ==== 4.2 Services configuration ==== | + | |
| - | On the Victron GX Device, go to // | + | |
| - | {{:venus-os:venus-html5-mqtt.png? | + | |
| - | Next, go to // | + | |
| - | ===== 5. Configuring Multiple Battery Monitors ===== | + | |
| - | {{youtube> | + | |
venus-os/mfd-furuno.1591888655.txt.gz · Last modified: by mbosma
