venus-os:mfd-furuno
venus-os:mfd-furuno [2020-07-17 11:50] – [2. Compatibility] mvader | venus-os:mfd-furuno [2020-07-28 12:40] – [2. Compatibility] mvader | ||
Line 11: | Line 11: | ||
- | The MFD integration is compatible with the following | + | The MFD integration is compatible with the following |
* NavNet TZtouch3 TZT12F | * NavNet TZtouch3 TZT12F | ||
* NavNet TZtouch3 TZT16F | * NavNet TZtouch3 TZT16F | ||
* NavNet TZtouch3 TZT19F | * NavNet TZtouch3 TZT19F | ||
* Navnet TZtouch2 TZT2BB Black box | * Navnet TZtouch2 TZT2BB Black box | ||
- | NavNet TZtouch3 MFDs need at least software version v1.08. The Navnet TZtouch2 TZT2BB needs at least software version v7. | + | NavNet TZtouch3 MFDs need at least software version v1.08. The Navnet TZtouch2 TZT2BB needs at least software version v7.01. |
Note that the Navnet TZtouch2 TZT**L** models are **not** supported. | Note that the Navnet TZtouch2 TZT**L** models are **not** supported. | ||
Line 38: | Line 38: | ||
- | It is possible to connect a router to the same LAN; and that way connect the GX Device to the internet. Make sure the //Gateway// and //DNS Server// settings of the GX are set to the IP address of the router. | + | It is possible to connect a router to the same LAN; and that way connect the GX Device to the internet. Make sure the //Gateway// and //DNS Server// settings of the GX are set to the IP address of the router, and that the router has its LAN IP addressing configured in the same subnet. |
:!: It is not possible to use a [[https:// | :!: It is not possible to use a [[https:// | ||
Line 58: | Line 58: | ||
The MFD can also be connected to the GX device using NMEA 2000, see [[https:// | The MFD can also be connected to the GX device using NMEA 2000, see [[https:// | ||
- | The MFD can be configured easily to display the data from the GX device. | + | The MFD can be configured easily to display the data from the GX device. |
+ | In order to properly display battery/DC data from Victron equipment, you need to change the data instances of the PGNs that are sent out. See here for how to do that: [[https:// | ||
To view NMEA 2000 devices on the MFD, go to //Settings > Initial Setup > Data Aquisition > Sensor List//. Here you can view basic information and change device instances and custom names. | To view NMEA 2000 devices on the MFD, go to //Settings > Initial Setup > Data Aquisition > Sensor List//. Here you can view basic information and change device instances and custom names. | ||
The following Victron PGNs are supported: | The following Victron PGNs are supported: | ||
* 127505 - Fluid level (tanks) | * 127505 - Fluid level (tanks) | ||
- | * 127506 - DC Detailed Status (limited support); State-of-charge, | + | * 127506 - DC Detailed Status (limited support); State-of-charge, |
- | * 127508 - Battery Status (limited support); Voltage, Current | + | * 127508 - Battery Status (limited support); Voltage, Current |
+ | **Notes** | ||
+ | - The current MFD firmware only supports 4 batteries | ||
+ | - Due to a bug in the MFD firmware, a negative current is shown as '' |
venus-os/mfd-furuno.txt · Last modified: 2023-06-22 19:27 by sloges
