venus-os:mfd-furuno
venus-os:mfd-furuno [2020-06-25 15:36] – [6. NMEA 2000] mbosma | venus-os:mfd-furuno [2023-06-22 19:27] (current) – Removed and linked to corresponding GX manual chapter sloges | ||
====== Furuno MFD Integration ====== | ====== Furuno MFD Integration ====== | ||
- | ===== 1. Introduction ===== | + | Moved to: https:// |
- | This document explains how to connect to Furuno MFDs using an Ethernet connection. | + | |
- | Note that there is an alternative method to connect, which is NMEA2000. See the [[https:// | + | |
- | The MFD integration is compatible with the following models: | + | |
- | * NavNet TZtouch3 TZT12F | + | |
- | * NavNet TZtouch3 TZT16F | + | |
- | * NavNet TZtouch3 TZT19F | + | |
- | * Navnet TZtouch2 TZT2BB Black box | + | |
- | NavNet TZtouch3 MFDs need at least software version v1.08. The Navnet TZtouch2 TZT2BB needs at least software version v7. | + | |
- | Note that the Navnet TZtouch2 TZT**L** models are **not** supported. | + | |
- | The Furuno device needs to be connected to the [[venus-os: | + | |
- | ==== 4.1 Ethernet configuration ==== | + | |
- | On the Victron GX Device, make sure that the Ethernet cable is connected and go to //Settings | + | |
- | ^ Setting | + | |
- | | IP Configuration | Manual | + | |
- | | IP address | + | |
- | | Netmask | + | |
- | | Gateway | + | |
- | | DNS server | + | |
- | {{:venus-os:furuno-ip-config.png? | + | |
- | It is possible to connect a router to the same LAN; and that way connect the GX Device to the internet. Make sure the //Gateway// and //DNS Server// settings of the GX are set to the IP address of the router. | + | |
- | ==== 4.2 Services configuration ==== | + | |
- | On the Victron GX Device, go to //Settings -> Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)// | + | |
- | Next, go to //Settings -> System Setup -> Scroll to the bottom -> Marine MFD App configuration// | + | |
- | {{:venus-os: | + | |
- | {{youtube> | + | |
- | ===== 6. NMEA 2000 ===== | + | |
- | The MFD can also be connected to the GX device using NMEA 2000, see [[https:// | + | |
- | The MFD can be configured easily to display the data from the GX device. There is no need to change any instance. | + | |
- | To view NMEA 2000 devices on the MFD, go to //Settings > Initial Setup > Data Aquisition > Sensor List//. Here you can view basic information and change device instances and custom names. | + | |
- | The following Victron PGNs are supported: | + | |
- | * 127505 | + | |
- | * 127506 | + | |
- | * 127508 | + |
venus-os/mfd-furuno.txt · Last modified: 2023-06-22 19:27 by sloges
