venus-os:mfd-furuno
venus-os:mfd-furuno [2020-06-25 15:36] – [6. NMEA 2000] mbosma | venus-os:mfd-furuno [2020-07-17 11:50] – [2. Compatibility] mvader | ||
Line 19: | Line 19: | ||
Note that the Navnet TZtouch2 TZT**L** models are **not** supported. | Note that the Navnet TZtouch2 TZT**L** models are **not** supported. | ||
===== 3. Wiring ===== | ===== 3. Wiring ===== | ||
Line 38: | Line 40: | ||
It is possible to connect a router to the same LAN; and that way connect the GX Device to the internet. Make sure the //Gateway// and //DNS Server// settings of the GX are set to the IP address of the router. | It is possible to connect a router to the same LAN; and that way connect the GX Device to the internet. Make sure the //Gateway// and //DNS Server// settings of the GX are set to the IP address of the router. | ||
==== 4.2 Services configuration ==== | ==== 4.2 Services configuration ==== | ||
On the Victron GX Device, go to //Settings -> Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)// | On the Victron GX Device, go to //Settings -> Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)// |
venus-os/mfd-furuno.txt · Last modified: 2023-06-22 19:27 by sloges
