venus-os:large
venus-os:large [2022-08-17 11:52] – [5.4 Controlling relays] mbosma | venus-os:large [2024-04-03 19:07] (current) – [5.1 Introduction] mvader | ||
Line 2: | Line 2: | ||
+ | **Node-RED** | ||
- | From VRM, a connection to Node-RED, the Node-RED dashboard and Signal K can be made. | + | |
- | Note that only the services that are enabled are shown in the VRM menu. | + | |
- | ==== 1.2 Status and where this development is going ==== | + | |
- | Currently, these images are available as beta versions. They work well, several users are using this without any issues; and are super happy with the provided functionality. | + | |
- | The remaining work are mostly small improvements, clean ups and testing. | + | - WiFi navigation and AIS data server to charting apps such as iSailor, Navionics, iNavX, Aqua Map. |
+ | - Automatic log book | ||
- | There will be two flavours | + | The [[https:// |
- | - the normal one as we've been building for years now. With all normal & supported functionality. | + | For more information on Signal K on Venus OS, see below chapter. |
- | - the large flavour. All the same as the normal one, but with addition of Signal K & Node-RED. | + | |
- | Switching between them is easy: a simple switch in the gui, see Settings -> Firmware -> Online updates -> Image type. | ||
- | Why are there two images, instead of just one? That is to save download and install time for the (vast majority) of users that will not use these features. SignalK and Node-RED increase the download (& installed) size enormously, and also they are really cool; but do not fall within normal Victron support. Which is why we want to keep them separate. | ||
===== 2. Where to find support ===== | ===== 2. Where to find support ===== | ||
- | There is and will be **no official support** on the functionalities | + | There is and will be no official support on the functionalities |
- | For support, turn to the [[https:// | + | For support, turn to the [[https:// |
- | There, first search if someone else had a similar question already. And if you can’t find such, then create a new question. | + | There, first search if someone else had a similar question already. And if you can’t find such, then create a new question. Make sure you add Node-RED to the topic. |
Line 46: | Line 39: | ||
+ | * Ekrano GX | ||
* Cerbo GX | * Cerbo GX | ||
+ | * Cerbo-S GX | ||
* Venus GX | * Venus GX | ||
* Octo GX | * Octo GX | ||
Line 53: | Line 48: | ||
Line 59: | Line 54: | ||
Line 67: | Line 62: | ||
Line 75: | Line 70: | ||
- | === Step 2. Update to the latest v2.90 beta file === | + | === Step 2. Update to the latest |
- | (And once v2.90 is released officially, its no longer needed | + | See Settings -> Firmware -> Online updates. For more information, refer to the user the manual of your GX device. |
- | Instructions and details on installing | + | === Step 3. Set the image type Venus OS Large === |
- | === Step 3. Switch | + | Go to Settings -> Firmware -> Online updates -> Image type: |
- | Go to Settings | + | {{ :venus-os: |
- | There select | + | Now, change |
- | The change-log is embedded in the (rather long) [[https:// | + | |
=== Step 3. Verify and enable === | === Step 3. Verify and enable === | ||
- | v2.8x: updates can only be done using the offline update | + | Both online and offline update |
- | v2.90 and later: | + | After installing |
+ | See [[https:// | ||
Line 117: | Line 127: | ||
- | The Node-RED | + | Node-RED |
- | __Standard nodes + Victron nodes__ | + | For developers: source code for the node-red-contrib-victron modules is [[https:// |
- | Node-RED comes with a core set of useful nodes, and within | + | |
- | For developers: source code for that is [[https:// | ||
- | note that updating the module is not possible from either the Node-RED editor as the commandline. The recommended way to get to the new node-red-contrib-victron version is to await a new Venus OS large build. | ||
==== 5.2 Back-up and restore ==== | ==== 5.2 Back-up and restore ==== | ||
Line 155: | Line 179: | ||
Make sure that there is always 30MB of free space remaining on the data partition. One of the [[https:// | Make sure that there is always 30MB of free space remaining on the data partition. One of the [[https:// | ||
Line 168: | Line 192: | ||
The relay in a BMV can be controlled. Make sure to set, using VictronConnect, | The relay in a BMV can be controlled. Make sure to set, using VictronConnect, | ||
+ | === SolarCharger | ||
- | === Multi & Quattro | + | === (VE.Bus connected-) |
- | Its not possible to control the alarm relay nor the AC-out 2 contactor of our inverter/ | + | Its not possible to control the alarm relay nor the AC-out 2 contactor of our inverter/ |
=== Charger relays === | === Charger relays === | ||
- | The only charger which has a relay that is controllable is the Phoenix | + | The only charger which has a relay that is controllable is the Smart IP43 Charger. To use that for remote control, set its mode, using the VictronConnect app, to be remote controllable. Note that its use is limited: the relay is only powered (and thus only controllable) when the charger is switched on. It doesn' |
==== 5.5 Node-RED Dashboard ==== | ==== 5.5 Node-RED Dashboard ==== | ||
Line 187: | Line 218: | ||
- | ==== 5.6. Node-RED FAQ ==== | + | ==== 5.6 Configuration files ==== |
+ | * [[https:// | ||
+ | The [[https:// | ||
- | === Q: Write/read file gives " | + | === Q1: Write/read file gives " |
Since Venus OS 2.90 and on wards, Node-RED no longer runs as user '' | Since Venus OS 2.90 and on wards, Node-RED no longer runs as user '' | ||
Line 206: | Line 287: | ||
- | === Q: How do I restart Node-RED from the Venus GUI? === | + | === Q4: How do I restart Node-RED from the Venus GUI? === |
In order to restart Node-RED you need to disable and enable it from the menu. You can find this under //Venus OS Large Features -> Node-RED//. | In order to restart Node-RED you need to disable and enable it from the menu. You can find this under //Venus OS Large Features -> Node-RED//. | ||
- | === Q: How does safe mode work and what is it? === | + | === Q5: How does safe mode work and what is it? === |
From the Venus GUI you can select Node-RED to be enabled in "safe mode". This means that Node-RED will start without starting the flows. This allows you to open the flows in the editor and make changes without the flows running. When you deploy your changes, the flows are then started. The safe mode can be handy if one of the flows has an error that causes high CPU loads on the Venus device or other issues. | From the Venus GUI you can select Node-RED to be enabled in "safe mode". This means that Node-RED will start without starting the flows. This allows you to open the flows in the editor and make changes without the flows running. When you deploy your changes, the flows are then started. The safe mode can be handy if one of the flows has an error that causes high CPU loads on the Venus device or other issues. | ||
- | === Q: Can I install the @signalk/ | + | === Q6: Can I install the @signalk/ |
No, at least not into the node-red instance which comes as part of Venus OS Large. To @signalk/ | No, at least not into the node-red instance which comes as part of Venus OS Large. To @signalk/ | ||
Line 225: | Line 306: | ||
- disable the Venus OS Node-RED, in GX Device -> Settings -> Venus OS Large -> Node-RED | - disable the Venus OS Node-RED, in GX Device -> Settings -> Venus OS Large -> Node-RED | ||
- install the Victron pallette into the Node-RED thats part of SignalK server | - install the Victron pallette into the Node-RED thats part of SignalK server | ||
+ | - Edit the ''/ | ||
+ | - Start Node-RED | ||
+ | module.exports = { | ||
Line 231: | Line 349: | ||
Line 237: | Line 355: | ||
+ | * Auqua Map | ||
+ | * iNavX | ||
+ | * iSailor | ||
+ | * Navionics | ||
Line 254: | Line 376: | ||
+ | * [[http:// | ||
- | And instead add information on what specifics we do in the Signal K install. | + | ==== 6.3 First use & configuring ==== |
- | - Signalk-node version is 1.37.5 | + | |
- | - Victron Venus Plugin, v1.22.0 | + | |
- | ==== 6.4 First use & configuring ==== | + | |
Line 318: | Line 417: | ||
Line 331: | Line 429: | ||
Line 336: | Line 435: | ||
+ | === Cerbo GX === | ||
+ | === Cerbo GX MK2 === | ||
+ | === Ekrano GX === | ||
Line 362: | Line 486: | ||
+ | # https:// | ||
+ | cp / | ||
+ | npm list -g | ||
+ | # /usr/lib | ||
+ | # ├── node-red@3.1.0 | ||
+ | # ├── npm@9.5.1 | ||
+ | svc -d / | ||
+ | ## Restore that file | ||
+ | mv / | ||
+ | cd / | ||
+ | svc -u / | ||
- | {{ :venus-os: | + | |
+ | - and similar. | ||
+ | The '' | ||
+ | root@einstein:/ | ||
+ | Filesystem | ||
+ | devtmpfs | ||
+ | tmpfs | ||
+ | tmpfs | ||
+ | tmpfs | ||
+ | overlay | ||
+ | The '' | ||
+ | root@Cerbo:/ | ||
+ | 1103640 / | ||
+ | 1099352 / | ||
+ | 1099276 / | ||
+ | 87048 / | ||
+ | 65732 / | ||
+ | 7188 / | ||
+ | 3920 / | ||
+ | 744 / | ||
+ | 164 / | ||
+ | 160 / | ||
+ | 116 / | ||
+ | 116 / | ||
+ | 164608 / | ||
+ | 160312 / | ||
+ | 160240 / | ||
+ | 87048 / | ||
+ | 65732 / | ||
+ | 7188 / | ||
+ | 3924 / | ||
+ | 744 / | ||
venus-os/large.1660729965.txt.gz · Last modified: 2022-08-17 11:52 by mbosma
