venus-os:large
venus-os:large [2021-09-09 15:41] – [5.1 Introduction] Moved password protection to the FAQ dfaber | venus-os:large [2024-04-03 19:07] (current) – [5.1 Introduction] mvader | ||
Line 2: | Line 2: | ||
+ | **Node-RED** | ||
+ | - Automatic log book | ||
Line 45: | Line 39: | ||
+ | * Ekrano GX | ||
* Cerbo GX | * Cerbo GX | ||
+ | * Cerbo-S GX | ||
* Venus GX | * Venus GX | ||
* Octo GX | * Octo GX | ||
Line 52: | Line 48: | ||
Line 58: | Line 54: | ||
Line 66: | Line 62: | ||
Line 74: | Line 70: | ||
- | * __RaspberryPi 3__ - Unfortunately, | + | * __RaspberryPi 3__ - No preparations required. |
- | | RaspberryPi3 | + | |
- | | RaspberryPi4 | + | |
+ | See [[https:// | ||
Line 118: | Line 127: | ||
- | The Node-RED editor | + | It is always wise to create an extra backup before performing an update of the firmware. |
Line 142: | Line 179: | ||
Line 155: | Line 192: | ||
+ | === SolarCharger | ||
Line 171: | Line 218: | ||
+ | * [[https:// | ||
+ | The [[https:// | ||
Line 186: | Line 287: | ||
+ | - Edit the ''/ | ||
+ | - Start Node-RED | ||
+ | module.exports = { | ||
Line 195: | Line 349: | ||
Line 201: | Line 355: | ||
+ | * Auqua Map | ||
+ | * iNavX | ||
+ | * iSailor | ||
+ | * Navionics | ||
Line 218: | Line 376: | ||
+ | * [[http:// | ||
Line 282: | Line 417: | ||
Line 295: | Line 429: | ||
Line 300: | Line 435: | ||
+ | === Cerbo GX === | ||
+ | === Cerbo GX MK2 === | ||
+ | === Ekrano GX === | ||
Line 326: | Line 486: | ||
+ | # https:// | ||
+ | cp / | ||
+ | npm list -g | ||
+ | # /usr/lib | ||
+ | # ├── node-red@3.1.0 | ||
+ | # ├── npm@9.5.1 | ||
+ | svc -d / | ||
+ | ## Restore that file | ||
+ | mv / | ||
+ | cd / | ||
+ | svc -u / | ||
- | {{ :venus-os: | + | |
+ | - and similar. | ||
+ | The '' | ||
+ | root@einstein:/ | ||
+ | Filesystem | ||
+ | devtmpfs | ||
+ | tmpfs | ||
+ | tmpfs | ||
+ | tmpfs | ||
+ | overlay | ||
+ | The '' | ||
+ | root@Cerbo:/ | ||
+ | 1103640 / | ||
+ | 1099352 / | ||
+ | 1099276 / | ||
+ | 87048 / | ||
+ | 65732 / | ||
+ | 7188 / | ||
+ | 3920 / | ||
+ | 744 / | ||
+ | 164 / | ||
+ | 160 / | ||
+ | 116 / | ||
+ | 116 / | ||
+ | 164608 / | ||
+ | 160312 / | ||
+ | 160240 / | ||
+ | 87048 / | ||
+ | 65732 / | ||
+ | 7188 / | ||
+ | 3924 / | ||
+ | 744 / | ||
venus-os/large.1631194892.txt.gz · Last modified: 2021-09-09 15:41 by dfaber
