venus-os:large
venus-os:large [2021-11-25 14:46] – [1.1 Venus OS Large, Node-RED and Signal K server?] dfaber | venus-os:large [2021-12-10 10:36] – [5.2 Installing extra nodes] dfaber | ||
Line 13: | Line 13: | ||
From VRM, a connection to Node-RED, the Node-RED dashboard and Signal K can be made. | From VRM, a connection to Node-RED, the Node-RED dashboard and Signal K can be made. | ||
Note that only the services that are enabled are shown in the VRM menu. | Note that only the services that are enabled are shown in the VRM menu. | ||
Line 122: | Line 122: | ||
- | The Node-RED editor | + | The Node-RED editor |
- | Please note that updating the '' | + | Please note that updating the '' |
==== 5.2 Installing extra nodes ==== | ==== 5.2 Installing extra nodes ==== | ||
Line 132: | Line 132: | ||
Line 193: | Line 193: | ||
+ | === Q: How do I restart Node-RED from the Venus GUI? === | ||
+ | === Q: How does safe mode work and what is it? === | ||
=== Q: Can I install the @signalk/ | === Q: Can I install the @signalk/ |
venus-os/large.txt · Last modified: 2024-04-03 19:07 by mvader
