venus-os:gx_solaredge
venus-os:gx_solaredge [2019-05-26 19:52] – [2. How to configure] mvader | venus-os:gx_solaredge [2019-05-26 23:23] – [1. Introduction] mvader | ||
Line 11: | Line 11: | ||
In other sorts of systems, for example Off-grid systems, or ESS systems in areas where grid feed-in is not allowed, using a SolarEdge PV solution is not supported by Victron. | In other sorts of systems, for example Off-grid systems, or ESS systems in areas where grid feed-in is not allowed, using a SolarEdge PV solution is not supported by Victron. | ||
- | Note that its not possible to use the SolarEdge Wattnode meter when used in a Victron ESS System. In laymans terms, doing so will put to captains on the same ship, both trying to regulate the power flow at the utility connection, which will fail / be unstable. | + | Note that its not possible to use the SolarEdge Wattnode meter when used in a Victron ESS System. In laymans terms, doing so will put two captains on the same ship, both trying to regulate the power flow at the utility connection, which will fail / be unstable. |
===== 2. How to configure ===== | ===== 2. How to configure ===== | ||
venus-os/gx_solaredge.txt · Last modified: 2021-09-21 16:22 by fjlacock
