venus-os:gx-lte
venus-os:gx-lte [2021-03-16 11:16] – mvader | venus-os:gx-lte [2022-01-06 11:36] – [8. Technical Data] mvader | ||
Line 77: | Line 77: | ||
+ | **Automatic recovery when disconnected** | ||
+ | When installing the GX 4G LTE in an area that you expect continuous internet coverage, you should enable the " | ||
+ | Note that if you are leaving internet service coverage areas (such as an RV on the move, or a boat leaving dock to go to sea) then it is recommend to disable this setting, so that your GX is not rebooting itself for no reason. Or set it, for example, to a two hour time-out. And accept a reboot every two hours when underway. | ||
Line 132: | Line 140: | ||
+ | === What to do if the GX LTE 4G is not staying connected? === | ||
+ | Enable the " | ||
===== 7. Supported Frequencies ===== | ===== 7. Supported Frequencies ===== | ||
Line 151: | Line 165: | ||
^ Outer dimensions (LxWxH) | 106x42.5x22 mm ([[https:// | ^ Outer dimensions (LxWxH) | 106x42.5x22 mm ([[https:// | ||
^ Voltage range | 8..70 VDC | | ^ Voltage range | 8..70 VDC | | ||
- | ^ Power draw | 2.5 W while 2G/3G data transfer\\ <1.0 W in idle mode\\ +0.4 W if GPS is enabled | | + | ^ Power draw | 2.5 W while 2G/3G/4G data transfer\\ <1.0 W in idle mode\\ +0.4 W if GPS is enabled | |
^ Recommended fuse size | 500 mA @ 12 V\\ 250 mA @ 24 V\\ 100 mA @ 48 V | | ^ Recommended fuse size | 500 mA @ 12 V\\ 250 mA @ 24 V\\ 100 mA @ 48 V | | ||
^ Wire gauge (power cable) | 0.5..1.5mm² / AWG 28..16 | | ^ Wire gauge (power cable) | 0.5..1.5mm² / AWG 28..16 | |
venus-os/gx-lte.txt · Last modified: 2022-10-12 10:05 by marmour
