venus-os:gx-lte
venus-os:gx-lte [2020-06-26 17:27] – All good! krenzke | venus-os:gx-lte [2022-07-13 08:19] – [Outdoor 4G GSM Antenna (not yet available)] marmour | ||
====== GX LTE 4G - Manual ====== | ====== GX LTE 4G - Manual ====== | ||
- | NOTE: DRAFT MANUAL. FIRST STOCK EXPECTED IN 2020 Q4 | ||
Line 8: | Line 7: | ||
==== 1.1 Product description ==== | ==== 1.1 Product description ==== | ||
- | The GX LTE is an accessory for [[venus-os: | + | The GX LTE is an accessory for [[venus-os: |
There are three models: | There are three models: | ||
Line 29: | Line 28: | ||
==== 1.2 Antennas and accessories ==== | ==== 1.2 Antennas and accessories ==== | ||
- | (DRAFT - THIS SECTION NEEDS UPDATING. EITHER THE SAME EXTERNAL ANTENNA CAN BE USED OR A NEW ONE IS NECESSARY - WILL BE CLEAR SOON) | + | A small indoor LTE antenna is included. As an option we also sell an outdoor LTE antenna: |
- | LTE: A small indoor LTE antenna is included. As an option we also sell an outdoor LTE antenna: | + | |
GPS: The GX LTE includes a built-in GPS receiver. With the optional GPS antenna installed, the system can be tracked as well as Geo-fenced on the VRM Portal. The required accessory is the GSM900200100 - Active GPS Antenna for GX LTE. | GPS: The GX LTE includes a built-in GPS receiver. With the optional GPS antenna installed, the system can be tracked as well as Geo-fenced on the VRM Portal. The required accessory is the GSM900200100 - Active GPS Antenna for GX LTE. | ||
Line 80: | Line 77: | ||
+ | **Automatic recovery when disconnected** | ||
+ | When installing the GX 4G LTE in an area that you expect continuous internet coverage, you should enable the " | ||
+ | Note that if you are leaving internet service coverage areas (such as an RV on the move, or a boat leaving dock to go to sea) then it is recommend to disable this setting, so that your GX is not rebooting itself for no reason. Or set it, for example, to a two hour time-out. And accept a reboot every two hours when underway. | ||
Line 135: | Line 140: | ||
+ | === What to do if the GX LTE 4G is not staying connected? === | ||
+ | Enable the " | ||
===== 7. Supported Frequencies ===== | ===== 7. Supported Frequencies ===== | ||
Line 141: | Line 152: | ||
^ Part number ^ Name ^ Region ^ Used module ^ Supported LTE Bands ^ | ^ Part number ^ Name ^ Region ^ Used module ^ Supported LTE Bands ^ | ||
- | | GSM100100400 | GX LTE 4G-E | EMEA/ | + | | GSM100100400 | GX LTE 4G-E | EMEA/ |
- | | GSM100200400 | GX LTE 4G-A | North America | SIMCom SIM7600A-H | 2, 4, 12 | | + | | GSM100200400 | GX LTE 4G-A | North America | SIMCom SIM7600A | 2, 4, 12 | |
- | | GSM100300400 | GX LTE 4G-SA | Australia/ | + | | GSM100300400 | GX LTE 4G-SA | Australia/ |
- | For more details, please refer to the [[https:// | + | For more details, please refer to the [[https:// |
==== 7.2 Notes regarding regional coverage ==== | ==== 7.2 Notes regarding regional coverage ==== | ||
Line 154: | Line 165: | ||
^ Outer dimensions (LxWxH) | 106x42.5x22 mm ([[https:// | ^ Outer dimensions (LxWxH) | 106x42.5x22 mm ([[https:// | ||
^ Voltage range | 8..70 VDC | | ^ Voltage range | 8..70 VDC | | ||
- | ^ Power draw | 2.5 W while 2G/3G data transfer\\ <1.0 W in idle mode\\ +0.4 W if GPS is enabled | | + | ^ Power draw | 2.5 W while 2G/3G/4G data transfer\\ <1.0 W in idle mode\\ +0.4 W if GPS is enabled | |
^ Recommended fuse size | 500 mA @ 12 V\\ 250 mA @ 24 V\\ 100 mA @ 48 V | | ^ Recommended fuse size | 500 mA @ 12 V\\ 250 mA @ 24 V\\ 100 mA @ 48 V | | ||
^ Wire gauge (power cable) | 0.5..1.5mm² / AWG 28..16 | | ^ Wire gauge (power cable) | 0.5..1.5mm² / AWG 28..16 | | ||
Line 161: | Line 172: | ||
===== 9. Accessory / Antennas ===== | ===== 9. Accessory / Antennas ===== | ||
==== Outdoor 2G and 3G GSM Antenna ==== | ==== Outdoor 2G and 3G GSM Antenna ==== | ||
- | + | This antenna can be used with the GX LTE 4G, for 2G, 3G as well as 4G bands. | |
- | NOTE WE ARE CHECKING WHAT ANTENNA TO USE | + | |
Line 169: | Line 180: | ||
^ Mounting option | Screw Mount | | ^ Mounting option | Screw Mount | | ||
^ Cable Type | Rg-316 | | ^ Cable Type | Rg-316 | | ||
- | ^ Cable Length | 0.25 m | | + | ^ Cable Length | 3.0 m | |
^ Connector | SMA Male Straight | | ^ Connector | SMA Male Straight | | ||
^ Frequencies | 800/ | ^ Frequencies | 800/ | ||
^ Signal Gain | 3 dbi | | ^ Signal Gain | 3 dbi | | ||
+ | ==== Outdoor 4G GSM Antenna ==== | ||
+ | This antenna is optimised for 4G frequency bands, and as such will have slightly better reception on the 4G network. | ||
+ | Mean while, if the 2G / 3G variant doesn' | ||
+ | ^ Part number | GSM900100400 | | ||
+ | ^ Mounting option | Screw Mount | | ||
+ | ^ Cable Type | tbd | | ||
+ | ^ Cable Length | 3.0 m | | ||
+ | ^ Connector | SMA Male Straight | | ||
+ | ^ Frequencies | tbd | | ||
+ | ^ Signal Gain | tbd | | ||
==== Active GPS Antenna ==== | ==== Active GPS Antenna ==== |
venus-os/gx-lte.txt · Last modified: 2022-10-12 10:05 by marmour
