venus-os:gx-lte
venus-os:gx-lte [2020-06-25 14:21] – [GX LTE 4G - Manual] marianka | venus-os:gx-lte [2020-06-25 14:49] – LTE Bands added + Link to module comparison table krenzke | ||
Line 31: | Line 31: | ||
(DRAFT - THIS SECTION NEEDS UPDATING. EITHER THE SAME EXTERNAL ANTENNA CAN BE USED OR A NEW ONE IS NECESSARY - WILL BE CLEAR SOON) | (DRAFT - THIS SECTION NEEDS UPDATING. EITHER THE SAME EXTERNAL ANTENNA CAN BE USED OR A NEW ONE IS NECESSARY - WILL BE CLEAR SOON) | ||
- | GSM: A small indoor | + | LTE: A small indoor |
- | * GSM900100100 - Outdoor 2G and 3G GSM Antenna for GX LTE | + | * GSM900100100 - Outdoor 2G, 3G and 4G Antenna for GX LTE |
GPS: The GX LTE includes a built-in GPS receiver. With the optional GPS antenna installed, the system can be tracked as well as Geo-fenced on the VRM Portal. The required accessory is the GSM900200100 - Active GPS Antenna for GX LTE. | GPS: The GX LTE includes a built-in GPS receiver. With the optional GPS antenna installed, the system can be tracked as well as Geo-fenced on the VRM Portal. The required accessory is the GSM900200100 - Active GPS Antenna for GX LTE. | ||
Line 94: | Line 94: | ||
==== Status Bar ==== | ==== Status Bar ==== | ||
- | GSM modem status can be checked at a glance by looking at the status bar. | + | Cellular |
^ Icon ^ Details ^ | ^ Icon ^ Details ^ | ||
Line 113: | Line 113: | ||
| SIM wrong | Type of SIM is not supported | | | SIM wrong | Type of SIM is not supported | | ||
- | [[http:// | + | |
===== 6. Trouble shooting ===== | ===== 6. Trouble shooting ===== | ||
Line 140: | Line 140: | ||
==== 7.1 Available models & their supported frequency bands ==== | ==== 7.1 Available models & their supported frequency bands ==== | ||
- | ^ Part number ^ Name ^ Region ^ Used module ^ | + | ^ Part number ^ Name ^ Region ^ Used module |
- | | GSM100100400 | GX LTE 4G-E | For EMEA/ | + | | GSM100100400 | GX LTE 4G-E | EMEA/ |
- | | GSM100200400 | GX LTE 4G-A | For North America | Simcom | + | | GSM100200400 | GX LTE 4G-A | North America | SIMCom |
- | | GSM100300400 | GX LTE 4G-SA | For Australia/ | + | | GSM100300400 | GX LTE 4G-SA | Australia/ |
- | MANUAL PLS ADD INFORMATION ON THE FREQUENCY BANDS 2G/3G/4G.. Perhaps its too much for in above table? | + | |
+ | For more details, please refer to the [[https:// | ||
==== 7.2 Notes regarding regional coverage ==== | ==== 7.2 Notes regarding regional coverage ==== | ||
venus-os/gx-lte.txt · Last modified: 2022-10-12 10:05 by marmour
