venus-os:gx-lte
venus-os:gx-lte [2020-06-25 13:39] – created mvader | venus-os:gx-lte [2022-07-13 08:19] – [Outdoor 4G GSM Antenna (not yet available)] marmour | ||
- | ====== GX LTE 4G manual | + | ====== GX LTE 4G - Manual |
- | TODO REPLACE BY GX LTE PICTURE | + | {{ :venus-os:gx_lte_4g-e_top_.png?400 |}} |
Line 9: | Line 7: | ||
==== 1.1 Product description ==== | ==== 1.1 Product description ==== | ||
- | The GX LTE is an accessory for [[venus-os: | + | The GX LTE is an accessory for [[venus-os: |
+ | There are three models: | ||
+ | ^ Part number ^ Name ^ Region ^ | ||
+ | | GSM100100400 | GX LTE 4G-E | For EMEA/ | ||
+ | | GSM100200400 | GX LTE 4G-A | For North America | | ||
+ | | GSM100300400 | GX LTE 4G-SA | For Australia/ | ||
+ | More information about supported frequencies and bands are in chapter 7.1 | ||
- | It requires a SIM card of the [[https:// | + | It requires a SIM card of the [[https:// |
- | See also the [[https:// | + | The GX LTE includes a built-in GPS receiver. When the optional GPS antenna is installed, the system can be tracked as well as Geo-fenced on the VRM Portal. |
- | This video Video explaining | + | Watch this video to learn how to connect using LAN, WiFi, and the GX GSM, which is the same with the GX LTE: |
{{youtube> | {{youtube> | ||
==== 1.2 Antennas and accessories ==== | ==== 1.2 Antennas and accessories ==== | ||
- | (DRAFT - THIS SECTION NEEDS UPDATING. EITHER THE SAME EXTERNAL ANTENNA CAN BE USED OR A NEW ONE IS NECESSARY - WILL BE CLEAR SOON) | ||
- | GSM: A small indoor | + | A small indoor |
- | * GSM900100100 | + | * GSM900100400 |
GPS: The GX LTE includes a built-in GPS receiver. With the optional GPS antenna installed, the system can be tracked as well as Geo-fenced on the VRM Portal. The required accessory is the GSM900200100 - Active GPS Antenna for GX LTE. | GPS: The GX LTE includes a built-in GPS receiver. With the optional GPS antenna installed, the system can be tracked as well as Geo-fenced on the VRM Portal. The required accessory is the GSM900200100 - Active GPS Antenna for GX LTE. | ||
Line 34: | Line 40: | ||
The GX LTE can be used with any of the [[venus-os: | The GX LTE can be used with any of the [[venus-os: | ||
- | The GX LTE requires Venus OS v2.54 or newer to be installed on the GX Device. | + | The GX LTE requires Venus OS v2.60 or newer to be installed on the GX Device. |
==== 1.4 When to use a mobile router instead ==== | ==== 1.4 When to use a mobile router instead ==== | ||
Line 71: | Line 77: | ||
+ | **Automatic recovery when disconnected** | ||
+ | When installing the GX 4G LTE in an area that you expect continuous internet coverage, you should enable the " | ||
+ | Note that if you are leaving internet service coverage areas (such as an RV on the move, or a boat leaving dock to go to sea) then it is recommend to disable this setting, so that your GX is not rebooting itself for no reason. Or set it, for example, to a two hour time-out. And accept a reboot every two hours when underway. | ||
Line 85: | Line 99: | ||
==== Status Bar ==== | ==== Status Bar ==== | ||
- | GSM modem status can be checked at a glance by looking at the status bar. | + | Cellular |
^ Icon ^ Details ^ | ^ Icon ^ Details ^ | ||
Line 104: | Line 118: | ||
| SIM wrong | Type of SIM is not supported | | | SIM wrong | Type of SIM is not supported | | ||
- | [[http:// | + | |
===== 6. Trouble shooting ===== | ===== 6. Trouble shooting ===== | ||
Line 127: | Line 141: | ||
- | ===== 7. Supported Frequencies (2G/3G) ===== | ||
- | ==== 7.1 Available models & their supported frequency bands ==== | + | === What to do if the GX LTE 4G is not staying connected? |
- | GSM100100100 - GX LTE 900/2100: | + | Enable the " |
- | * 2G (GSM/ | + | |
- | * 3G (UMTS/ | + | |
- | * The used GSM module is a Simcom SIM5360E. | + | ===== 7. Supported Frequencies ===== |
+ | ==== 7.1 Available models & their supported frequency bands ==== | ||
- | GSM100200100 - GX LTE 850/ | + | ^ Part number ^ Name ^ Region ^ Used module ^ Supported |
- | * 2G (GSM/ | + | | GSM100100400 | GX LTE 4G-E | EMEA/Korea/Thailand | SIMCom SIM7600E | 1, 3, 5, 7, 8, 20, 38, 40, 41 | |
- | * 3G (UMTS/HSPA+): 850/1900 MHz (Dual-Band) | + | | GSM100200400 | GX LTE 4G-A | North America | SIMCom SIM7600A | 2, 4, 12 | |
- | * The used GSM module is the Simcom SIM5360A. | + | | GSM100300400 | GX LTE 4G-SA | Australia/ |
- | * Expected in first stock in 2020 Q3. And only short lived; since its successor, the GX LTE 4G, having 2G/3G and also 4G support is also coming soon. | + | |
+ | For more details, please refer to the [[https:// | ||
==== 7.2 Notes regarding regional coverage ==== | ==== 7.2 Notes regarding regional coverage ==== | ||
- | A good reference to check frequencies is [[https:// | + | A good reference to check frequencies is [[https:// |
===== 8. Technical Data ===== | ===== 8. Technical Data ===== | ||
Line 150: | Line 165: | ||
^ Outer dimensions (LxWxH) | 106x42.5x22 mm ([[https:// | ^ Outer dimensions (LxWxH) | 106x42.5x22 mm ([[https:// | ||
^ Voltage range | 8..70 VDC | | ^ Voltage range | 8..70 VDC | | ||
- | ^ Power draw | 2.5 W while 2G/3G data transfer\\ <1.0 W in idle mode\\ +0.4 W if GPS is enabled | | + | ^ Power draw | 2.5 W while 2G/3G/4G data transfer\\ <1.0 W in idle mode\\ +0.4 W if GPS is enabled | |
^ Recommended fuse size | 500 mA @ 12 V\\ 250 mA @ 24 V\\ 100 mA @ 48 V | | ^ Recommended fuse size | 500 mA @ 12 V\\ 250 mA @ 24 V\\ 100 mA @ 48 V | | ||
^ Wire gauge (power cable) | 0.5..1.5mm² / AWG 28..16 | | ^ Wire gauge (power cable) | 0.5..1.5mm² / AWG 28..16 | | ||
Line 157: | Line 172: | ||
===== 9. Accessory / Antennas ===== | ===== 9. Accessory / Antennas ===== | ||
==== Outdoor 2G and 3G GSM Antenna ==== | ==== Outdoor 2G and 3G GSM Antenna ==== | ||
+ | This antenna can be used with the GX LTE 4G, for 2G, 3G as well as 4G bands. | ||
^ Part number | GSM900100100 | | ^ Part number | GSM900100100 | | ||
^ Mounting option | Screw Mount | | ^ Mounting option | Screw Mount | | ||
^ Cable Type | Rg-316 | | ^ Cable Type | Rg-316 | | ||
- | ^ Cable Length | 0.25 m | | + | ^ Cable Length | 3.0 m | |
^ Connector | SMA Male Straight | | ^ Connector | SMA Male Straight | | ||
^ Frequencies | 800/ | ^ Frequencies | 800/ | ||
^ Signal Gain | 3 dbi | | ^ Signal Gain | 3 dbi | | ||
+ | ==== Outdoor 4G GSM Antenna ==== | ||
+ | This antenna is optimised for 4G frequency bands, and as such will have slightly better reception on the 4G network. | ||
+ | Mean while, if the 2G / 3G variant doesn' | ||
+ | ^ Part number | GSM900100400 | | ||
+ | ^ Mounting option | Screw Mount | | ||
+ | ^ Cable Type | tbd | | ||
+ | ^ Cable Length | 3.0 m | | ||
+ | ^ Connector | SMA Male Straight | | ||
+ | ^ Frequencies | tbd | | ||
+ | ^ Signal Gain | tbd | | ||
==== Active GPS Antenna ==== | ==== Active GPS Antenna ==== |
venus-os/gx-lte.txt · Last modified: 2022-10-12 10:05 by marmour
