venus-os:gx-gsm
GX GSM
DRAFT: function & product not released yet.
Trouble shooting
Step Details
1 Power Check that the blue LED is either lit continuous or blinking
2 USB The modem must be connected to USB, and visible in the Settings → GSM modem menu
3 Simcard (feature is still being added to the software)
4 Signal strength 15 or higher (and see below table)
5 Network
Antenna reception interpretation
Even when there is no simcard inserted, you can check signal strength.
0 = -113 dBm or less
1 = -111 dBm
2 = -109 .. -53 dBm
31 = - 51dBm
99 = not known or not detectable
-50 to -75 dBm: high signal
-76 to 90 dBm: medium signal
-91 to -100: low signal
-101 to -120 dBm poor signal
You also need to remember that an outdoor antenna typically increases received signal by 15 dB to 25 dB. (verify)
TODO: replace above by something meaning full, ie indicate the signal strenght to the user in such way that he doesn't need to memorize rssi or other tables.
venus-os/gx-gsm.1532598550.txt.gz · Last modified: 2018-07-26 11:49 by mvader
