venus-os:gx-gsm
| venus-os:gx-gsm [2019-09-06 07:26] – [3. Configuration] marmour | venus-os:gx-gsm [2023-01-19 08:47] (current) – Deleted. A new manual has been added to the product page. sloges | ||
| Line 1: | Line 1: | ||
| - | ====== GX GSM manual ====== | ||
| - | ===== 1. Introduction ===== | ||
| - | The GX GSM is an accessory for [[venus-os: | ||
| - | It requires a SIM card of the [[https:// | ||
| - | See also the [[https:// | ||
| - | Video explaining how to connect using LAN, WiFi, and the GX GSM: | ||
| - | {{youtube> | ||
| - | === Antennas and accessories === | ||
| - | GSM: A small indoor GSM antenna is included. As an option we also sell an outdoor GSM antenna: | ||
| - | * GSM900100100 - Outdoor 2G and 3G GSM Antenna for GX GSM | ||
| - | GPS: The unit has a built-in GPS receiver. An antenna is not included; to use the GPS received; purchase the GPS Antenna. | ||
| - | * GSM900200100 - Active GPS Antenna for GX GSM | ||
| - | See bottom of this manual for photos and specs of both optional antennas. | ||
| - | ==== Compatibility ==== | ||
| - | The GX GSM can be used with any of the [[venus-os: | ||
| - | * Color Control GX | ||
| - | * Venus GX | ||
| - | * Octo GX | ||
| - | The GX GSM requires Venus OS v2.22 or newer to be installed on the GX Device. | ||
| - | ==== When to use a mobile router instead ==== | ||
| - | The GX GSM only provides an internet connection for the [[venus-os: | ||
| - | For installations where more devices need internet, such as a yacht or RV, consider installing a mobile router instead. [[https:// | ||
| - | ===== 2. Installation ===== | ||
| - | Mount the device and connect the antenna. Consider using the outdoor antenna when installing the GX GSM in a closed metal enclosure. | ||
| - | Insert the SIM card. You will need to eject the SIM card tray with a pen or other pointy object. Be aware that the SIM card tray sits slightly recessed inside the unit. Be sure to push it all the way in. | ||
| - | Connect the GX GSM to the GX-device with the supplied USB cable. Use a USB hub if all USB sockets are already in use. | ||
| - | Connect DC power supply (8 to 70 VDC). A 1.4M wire is included, with M10 lugs and an inline fuse. | ||
| - | After power-up, the blue LED will be solid blue. Next, once it has registered on a network, it will start blinking slowly. Finally, when it has established the internet connection, it will be blinking fast. | ||
| - | ===== 3. Configuration ===== | ||
| - | When using a SIM card with its SIM-pin security disabled, the system will work without further configuration. Verify operation by .. ? (Check VRM Last log data?) | ||
| - | Setting a SIM pin helps reducing the risk of the SIM card being stolen and used. Use a mobile phone to set the SIM pin, and there after configure it on the GX-device. | ||
| - | Settings -> GSM modem -> PIN code | ||
| - | Some mobile networks require manual configuration of an APN specially when roaming. Contact your operator. | ||
| - | APN name can be configured in Settings -> GSM Modem -> APN. | ||
| - | ===== 4. Status ===== | ||
| - | GSM modem status can be checked at a glance by looking at the status bar. | ||
| - | ^ Icon ^ Details ^ | ||
| - | ===== 6. GPS ===== | ||
| - | When the optional antenna is added; the position will be visible like this: | ||
| - | Also the position is sent to the [[https:// | ||
| - | ===== 5. Trouble shooting ===== | ||
| - | ^ ^ Step | ||
| - | | 1 | Power | Check that the blue LED is either lit continuous or blinking | ||
| - | | 2 | USB | The modem must be connected to USB, and visible in the Settings -> GSM modem menu | | ||
| - | | 3 | Simcard | If enabled, PIN code must be configured in Settings -> GSM modem -> PIN | | ||
| - | | 4 | Signal strength | 1 bar for VRM logging, 2/3 bars for remote console | | ||
| - | | 5 | Network | Check that a network name is visible. If it is not, contact your simcard provider and/or insert the simcard in a phone to double check its operation.| | ||
| - | You also need to remember that an outdoor antenna typically increases received signal by 15 dB to 25 dB. (verify) | ||
| - | ===== 6. Supported Frequencies (2G/3G) ===== | ||
| - | * 2G (GSM/ | ||
| - | * 3G (UMTS/ | ||
| - | Please notice: In Northern America 1900 MHz is the most common frequency for 3G, which is unsupported for the current version of GX GSM. | ||
| - | In case of uncertainty please double-check: | ||
| - | ===== 7. Technical Data ===== | ||
| - | ^ Outer dimensions (LxWxH) | 106x42.5x22 mm ([[https:// | ||
| - | ^ Voltage range | 8..70 VDC | | ||
| - | ^ Power draw | 2.5 W while 2G/3G data transfer\\ <1.0 W in idle mode\\ +0.4 W if GPS is enabled | | ||
| - | ^ Recommended fuse size | 500 mA @ 12 V\\ 250 mA @ 24 V\\ 100 mA @ 48 V | | ||
| - | ^ Wire gauge (power cable) | 0.5..1.5mm² / AWG 28..16 | | ||
| - | ^ Antenna connector | Type SMA Female | | ||
| - | ^ SIM card | Regular Mini SIM | | ||
| - | ===== 8. Accessory / Antennas ===== | ||
| - | ==== Outdoor 2G and 3G GSM Antenna ==== | ||
| - | ^ Part number | GSM900100100 | | ||
| - | ^ Mounting option | Screw Mount | | ||
| - | ^ Cable Type | Rg-316 | | ||
| - | ^ Cable Length | 0.25 m | | ||
| - | ^ Connector | SMA Male Straight | | ||
| - | ^ Frequencies | 800/ | ||
| - | ^ Signal Gain | 3 dbi | | ||
| - | ==== Active GPS Antenna ==== | ||
| - | ^ Part number | GSM900200100 | | ||
| - | ^ Mounting option | Magnet | | ||
| - | ^ Cable Type | Rg-174 | | ||
| - | ^ Cable Length | 3.0 m | | ||
| - | ^ Frequency | 1575.42 MHz | | ||
| - | ^ Impedance | 50 Ω | | ||
venus-os/gx-gsm.1567754781.txt.gz · Last modified: by marmour
