venus-os:gx-gsm
venus-os:gx-gsm [2019-01-22 09:43] – external edit 127.0.0.1venus-os:gx-gsm [2023-01-19 08:47] (current) – Deleted. A new manual has been added to the product page. sloges
-====== GX GSM manual ======
-{{:venus-os:gx_gsm_web.png?400 |}}
-===== 1. Introduction =====
-The GX GSM is an accessory for [[venus-os:start|Venus-device]]s. It is a cellular modem; providing a mobile internet for the system and connection to Victron Remote Management (VRM).
-It requires a SIM card of the [[https://socialcompare.com/en/comparison/sim-card-format-and-size-comparison|Mini-SIM format]]; and connects to the [[venus-os:start|Venus-device]] with a (supplied) 1m USB cable.
-See also the [[https://www.victronenergy.com/accessories/gx-gsm|GX GSM Product Page]].
-=== Antennas and accessories ===
-GSM: A small indoor GSM antenna is included. As an option we also sell an outdoor GSM antenna:
-  * GSM900100100 - Outdoor 2G and 3G GSM Antenna for GX GSM
-GPS: The unit has a built-in GPS receiver. An antenna is not included; to use the GPS received; purchase the GPS Antenna.
-  * GSM900200100 - Active GPS Antenna for GX GSM
-See bottom of this manual for photos and specs of both optional antennas.
-==== Compatibility ====
-  * Color Control GX
-  * Venus GX
-  * Octo GX
-The GX GSM requires Venus OS v2.22 or newer to be installed on the [[venus-os:start|Venus-device]].
-==== When to use a mobile router instead ====
-The GX GSM only provides an internet connection for the [[venus-os:start|Venus-device]]: there is no option to share the internet to laptops, phones, or other devices.
-For installations where more devices need internet, such as a yacht or RV, consider installing a mobile router instead. [[https://www.victronenergy.com/live/ccgx:start#internet_connectivity|More information here.]]
-===== 2. Installation =====
-Mount the device and connect the antenna. Consider using the outdoor antenna when installing the GX GSM in a closed metal enclosure.
-Insert the SIM card. You will need to eject the SIM card tray with a pen or other pointy object. Be aware that the SIM card try sits slightly recessed inside the unit. Be sure to push it all the way in.
-Connect the GX GSM to the Venus device with the supplied USB cable. Use a USB hub if all USB sockets are already in use.
-Connect DC power supply (8 to 70 VDC). A 1.4M wire is included, with M10 lugs and an inline fuse.
-After power-up, the blue LED will be solid blue. Next, once it has registered on a network, it will start blinking slowly. Finally, when it has established the internet connection, it will be blinking fast.
-===== 3. Configuration =====
-{{:venus-os:gsm-settings-full.png?direct&480|}}
-When using a SIM card with its SIM-pin security disabled, the system will work without further configuration. Verify operation by .. ? (Check VRM Last log data?)
-Setting a SIM pin helps reducing the risk of the SIM card being stolen and used. Use a mobile phone to set the SIM pin, and there after configure it on the Venus device.
-Settings -> GSM modem -> PIN code
-{{:venus-os:gsm-enter-pincode.png?direct&480|}}
-Some mobile networks require manual configuration of an APN specially when roaming. Contact your operator.
-APN name can be configured in Settings -> GSM Modem -> APN.
-{{:venus-os:gsm-apn-config.png?direct&480|}}
-===== 4. Status =====
-GSM modem status can be checked at a glance by looking at the status bar.
-^ Icon ^ Details ^
-| {{:venus-os:gsm-status-signalstrength.png?nolink&27}}     | GSM modem is connected to network, but not to the internet (no data connection). Either on purpose, because an ethernet or WiFi connection is available. |
-| {{:venus-os:gsm-status-gsm-internet.png?nolink&48|}}      | GSM modem is properly configured, the 3G/E/etc icon reflects that the GSM modem internet connection is in use. |
-| {{:venus-os:gsm-status-gsm-plus-wifi.png?nolinkx&54|}}    | WiFi is available and its internet connection is in use. WiFi has priority over GSM. |
-| {{:venus-os:gsm-status-pin-required.png?nolink&27|}}      | SIM PIN code is required. |
-| {{:venus-os:gsm-status-roaming.png?nolink&27|}}           | Roaming, only informative. To use internet connection while roaming it needs to be enabled in \\ Settings -> GSM modem -> Allow roaming.|
-===== 6. GPS =====
-When the optional antenna is added; the position will be visible like this:
-{{:venus-os:gps-settings-full.png?direct&480|}}
-Also the position is sent to the [[https://professional.victronenergy.com|VRM Portal]].
-===== 5. Trouble shooting =====
-^   ^ Step   ^  Details                                   ^
-| 1 | Power  | Check that the blue LED is either lit continuous or blinking  |
-| 2 | USB    | The modem must be connected to USB, and visible in the Settings -> GSM modem menu |
-| 3 | Simcard | If enabled, PIN code must be configured in Settings -> GSM modem -> PIN |
-| 4 | Signal strength | 1 bar for VRM logging, 2/3 bars for remote console |
-| 5 | Network | Check that a network name is visible. If it is not, contact your simcard provider and/or insert the simcard in a phone to double check its operation.|
-You also need to remember that an outdoor antenna typically increases received signal by 15 dB to 25 dB.  (verify)
-===== 6. Technical Data =====
-^ Outer dimensions (LxWxH) | 106x42.5x22 mm ([[https://www.victronenergy.de/upload/documents/GX-GSM-Dimensions.pdf|Drawing]]) |
-^ Voltage range | 8..70 VDC |
-^ Power draw | 2.5 W while 2G/3G data transfer\\ <1.0 W in idle mode\\ +0.4 W if GPS is enabled |
-^ Recommended fuse size | 500 mA @ 12 V\\ 250 mA @ 24 V\\ 100 mA @ 48 V |
-^ Wire gauge (power cable) | 0.5..1.5mm² / AWG 28..16 |
-^ Antenna connector | Type SMA Female |
-^ SIM card | Regular Mini SIM |
-===== 7. Accessory / Antennas =====
-==== Outdoor 2G and 3G GSM Antenna ====
-{{:venus-os:gsm900100100.png?nolink&250 |}}
-^ Part number | GSM900100100 |
-^ Mounting option | Screw Mount |
-^ Cable Type | Rg-316 |
-^ Cable Length | 0.25 m |
-^ Connector | SMA Male Straight |
-^ Frequencies | 800/900/1800/1900/2100 MHz |
-^ Signal Gain | 3 dbi |
-==== Active GPS Antenna ====
-{{:venus-os:gsm900200100.png?nolink&250 |}}
-^ Part number | GSM900200100 |
-^ Mounting option | Magnet |
-^ Cable Type | Rg-174 |
-^ Cable Length | 3.0 m |
-^ Frequency | 1575.42 MHz  |
-^ Impedance | 50 Ω |
venus-os/gx-gsm.1548150208.txt.gz · Last modified: by 127.0.0.1
