venus-os:gx-gsm
venus-os:gx-gsm [2022-04-26 14:20] – [Outdoor 2G and 3G GSM Antenna] marmour | venus-os:gx-gsm [2023-01-19 09:47] (current) – Deleted. A new manual has been added to the product page. sloges | ||
- | ====== GX GSM manual ====== | ||
- | ===== 1. Introduction ===== | ||
- | ==== 1.1 Product description ==== | ||
- | The GX GSM is an accessory for [[venus-os: | ||
- | It requires a SIM card of the [[https:// | ||
- | See also the [[https:// | ||
- | Video explaining how to connect using LAN, WiFi, and the GX GSM: | ||
- | {{youtube> | ||
- | ==== 1.2 Warning: maybe use the GX LTE 4G instead ==== | ||
- | The product described in this manual, is being succeeded with the newer [[https:// | ||
- | The GX GSM works only with 2G and 3G networks, which are -slowly- being shut down in various countries. Hence, depending on the location of installation, | ||
- | ==== 1.4 Antennas and accessories ==== | ||
- | GSM: A small indoor GSM antenna is included. As an option we also sell an outdoor GSM antenna: | ||
- | * GSM900100100 - Outdoor 2G and 3G GSM Antenna for GX GSM | ||
- | GPS: The unit has a built-in GPS receiver. An antenna is not included; to use the GPS received; purchase the GPS Antenna. | ||
- | * GSM900200100 - Active GPS Antenna for GX GSM | ||
- | [[venus-os: | ||
- | ==== 1.5 GX Compatibility ==== | ||
- | The GX GSM can be used with any of the [[venus-os: | ||
- | The GX GSM requires Venus OS v2.22 or newer to be installed on the GX Device. | ||
- | ==== 1.6 When to use a mobile router instead ==== | ||
- | The GX GSM provides an internet connection for the [[venus-os: | ||
- | For installations where more devices need internet, such as a yacht or RV, consider installing a mobile router instead. [[https:// | ||
- | ===== 2. Installation ===== | ||
- | Mount the device and connect the antenna. Consider using the outdoor antenna when installing the GX GSM in a closed metal enclosure. | ||
- | Insert the SIM card. You will need to eject the SIM card tray with a pen or other pointy object. Be aware that the SIM card tray sits slightly recessed inside the unit. Be sure to push it all the way in. | ||
- | Connect the GX GSM to the GX-device with the supplied USB cable. Use a USB hub if all USB sockets are already in use. | ||
- | Connect DC power supply (8 to 70 VDC). A 1.4M wire is included, with M10 lugs and an inline fuse. | ||
- | After power-up, the blue LED will be solid blue. Next, once it has registered on a network, it will start blinking slowly. Finally, when it has established the internet connection, it will be blinking fast. | ||
- | ===== 3. Configuration ===== | ||
- | When using a SIM card with its SIM-pin security disabled, the system will work without further configuration. | ||
- | Setting a SIM pin helps reducing the risk of the SIM card being stolen and used. Use a mobile phone to set the SIM pin, and there after configure it on the GX-device. | ||
- | Settings -> GSM modem -> PIN code | ||
- | Some mobile networks require manual configuration of an APN specially when roaming. Contact your operator. | ||
- | APN name can be configured in Settings -> GSM Modem -> APN. | ||
- | **Automatic recovery when disconnected** | ||
- | When installing the GX GSM, or GX 4G LTE in an area that you expect continuous internet coverage, you should enable the " | ||
- | Note that if you are leaving internet service coverage areas (such as an RV on the move, or a boat leaving dock to go to sea) then it is recommend to disable this setting, so that your GX is not rebooting itself for no reason. Or set it, for example, to a two hour time-out. And accept a reboot every two hours when underway. | ||
- | ===== 4. GPS ===== | ||
- | When the optional antenna is added; the position will be visible like this: | ||
- | Also the position is sent to the [[https:// | ||
- | ===== 5. Status ===== | ||
- | ==== Status Bar ==== | ||
- | GSM modem status can be checked at a glance by looking at the status bar. | ||
- | ^ Icon ^ Details ^ | ||
- | ==== SIM Status ==== | ||
- | ^ Status ^ Description ^ | ||
- | | Ready | SIM card is installed properly and registered to the network | | ||
- | | SIM not inserted | SIM card is missing or not inserted properly. SIM tray might hang out a little. | | ||
- | | PIN required | SIM card requires 4 digit PIN for unlock. | | ||
- | | PUK required | SIM is locked due to wrong PIN inputs. 8 digit PUK is required to release the lock state. | | ||
- | | SIM failure | SIM does not respond - might be broken | | ||
- | | SIM busy | SIM is in busy state | | ||
- | | SIM wrong | Type of SIM is not supported | | ||
- | [[http:// | ||
- | ===== 6. Trouble shooting ===== | ||
- | There are many reasons for modem internet connection to not work. Carefully go through each step of this trouble shooting guide. Make sure to start at the first step. When asking for help, make sure to mention each step taken and the result. | ||
- | ^ Step ^^ Details | ||
- | | 1 | Power | Check that the blue LED is either lit continuous or blinking | ||
- | | 2 | USB connection | ||
- | | 3 | Simcard status | Check the SIM Status in the menu, it must show " | ||
- | | 4 | Signal strength | 1 bar minimum for VRM logging, 2 or 3 bars are necessary for a working remote console | | ||
- | | 5 | Carrier registration | Check that a name of a Cellular provider is visible in the " | ||
- | | 6 | Internet connection | Verify that the Internet shows " | ||
- | | 7 | Connection to VRM Portal | Verify that the VRM Portal menu shows a recent last connection time. See Settings -> VRM Portal. For more details, see [[https:// | ||
- | An [[venus-os: | ||
- | Note that Ethernet and WiFi connections have priority over the cellular connection. Even when the available Ethernet | ||
- | This screenshot shows how all details look when everything is OK: | ||
- | === What to do if the GX GSM is not staying connected? === | ||
- | Enable the " | ||
- | ===== 7. Supported Frequencies (2G/3G) ===== | ||
- | ==== 7.1 Available models & their supported frequency bands ==== | ||
- | GSM100100100 - GX GSM 900/2100: | ||
- | * 2G (GSM/ | ||
- | * 3G (UMTS/ | ||
- | * The used GSM module is a Simcom SIM5360E. | ||
- | GSM100200100 - GX GSM 850/ | ||
- | * 2G (GSM/ | ||
- | * The used GSM module is the Simcom SIM5360A. | ||
- | * Expected in first stock in 2020 Q3. And only short lived; since its successor, the GX LTE 4G, having 2G/3G and also 4G support is also coming soon. | ||
- | ==== 7.2 Notes regarding regional coverage ==== | ||
- | USA, Mexico, Canada and most of South America: 1900 MHz is the most common frequency for 3G, which is unsupported for the current version of GX GSM. But a second model is coming in 2020, see above. | ||
- | Australia: The 900MHz 3G frequency in remote areas is typically provided by Optus. Telstra' | ||
- | In case of uncertainty please double-check: | ||
- | ===== 8. Technical Data ===== | ||
- | ^ Outer dimensions (LxWxH) | 106x42.5x22 mm ([[https:// | ||
- | ^ Voltage range | 8..70 VDC | | ||
- | ^ Power draw | 2.5 W while 2G/3G data transfer\\ <1.0 W in idle mode\\ +0.4 W if GPS is enabled | | ||
- | ^ Recommended fuse size | 500 mA @ 12 V\\ 250 mA @ 24 V\\ 100 mA @ 48 V | | ||
- | ^ Wire gauge (power cable) | 0.5..1.5mm² / AWG 28..16 | | ||
- | ^ Antenna connector | Type SMA Female | | ||
- | ^ SIM card | Regular Mini SIM | | ||
- | ===== 9. Accessory / Antennas ===== | ||
- | ==== Outdoor 2G and 3G GSM Antenna ==== | ||
- | ^ Part number | GSM900100100 | | ||
- | ^ Mounting option | Screw Mount | | ||
- | ^ Cable Type | Rg-316 | | ||
- | ^ Cable Length | 3.0 m | | ||
- | ^ Connector | SMA Male Straight | | ||
- | ^ Frequencies | 800/ | ||
- | ^ Signal Gain | 3 dbi | | ||
- | ==== Active GPS Antenna ==== | ||
- | ^ Part number | GSM900200100 | | ||
- | ^ Mounting option | Magnet | | ||
- | ^ Cable Type | Rg-174 | | ||
- | ^ Frequency | 1575.42 MHz | | ||
- | ^ Impedance | 50 Ω | | ||
