venus-os:gx-gsm
venus-os:gx-gsm [2021-05-27 21:24] – [3. Configuration] mvader | venus-os:gx-gsm [2022-01-06 11:35] – mvader | ||
Line 17: | Line 17: | ||
{{youtube> | {{youtube> | ||
- | ==== 1.2 Antennas and accessories ==== | + | ==== 1.2 Warning: maybe use the GX LTE 4G instead ==== |
+ | The product described in this manual, is being succeeded with the newer [[https:// | ||
+ | The GX GSM works only with 2G and 3G networks, which are -slowly- being shut down in various countries. Hence, depending on the location of installation, | ||
+ | ==== 1.4 Antennas and accessories ==== | ||
GSM: A small indoor GSM antenna is included. As an option we also sell an outdoor GSM antenna: | GSM: A small indoor GSM antenna is included. As an option we also sell an outdoor GSM antenna: | ||
Line 29: | Line 35: | ||
[[venus-os: | [[venus-os: | ||
- | ==== 1.3 Compatibility ==== | + | ==== 1.5 GX Compatibility ==== |
The GX GSM can be used with any of the [[venus-os: | The GX GSM can be used with any of the [[venus-os: | ||
Line 35: | Line 41: | ||
The GX GSM requires Venus OS v2.22 or newer to be installed on the GX Device. | The GX GSM requires Venus OS v2.22 or newer to be installed on the GX Device. | ||
- | ==== 1.4 When to use a mobile router instead ==== | + | ==== 1.6 When to use a mobile router instead ==== |
The GX GSM provides an internet connection for the [[venus-os: | The GX GSM provides an internet connection for the [[venus-os: |
