venus-os:gx-gsm
venus-os:gx-gsm [2021-05-27 11:39] – guystewart | venus-os:gx-gsm [2022-01-06 11:35] – mvader | ||
Line 17: | Line 17: | ||
{{youtube> | {{youtube> | ||
- | ==== 1.2 Antennas and accessories ==== | + | ==== 1.2 Warning: maybe use the GX LTE 4G instead ==== |
+ | The product described in this manual, is being succeeded with the newer [[https:// | ||
+ | The GX GSM works only with 2G and 3G networks, which are -slowly- being shut down in various countries. Hence, depending on the location of installation, | ||
+ | ==== 1.4 Antennas and accessories ==== | ||
GSM: A small indoor GSM antenna is included. As an option we also sell an outdoor GSM antenna: | GSM: A small indoor GSM antenna is included. As an option we also sell an outdoor GSM antenna: | ||
Line 29: | Line 35: | ||
[[venus-os: | [[venus-os: | ||
- | ==== 1.3 Compatibility ==== | + | ==== 1.5 GX Compatibility ==== |
The GX GSM can be used with any of the [[venus-os: | The GX GSM can be used with any of the [[venus-os: | ||
Line 35: | Line 41: | ||
The GX GSM requires Venus OS v2.22 or newer to be installed on the GX Device. | The GX GSM requires Venus OS v2.22 or newer to be installed on the GX Device. | ||
- | ==== 1.4 When to use a mobile router instead ==== | + | ==== 1.6 When to use a mobile router instead ==== |
The GX GSM provides an internet connection for the [[venus-os: | The GX GSM provides an internet connection for the [[venus-os: | ||
Line 73: | Line 79: | ||
**Automatic recovery when disconnected** | **Automatic recovery when disconnected** | ||
- | When installing the GX GSM, or GX 4G LTE in an area that you expect | + | When installing the GX GSM, or GX 4G LTE in an area that you expect |
- | Enabling this setting will eliminate the need to manually | + | |
- | Note if you are leaving internet service coverage areas (such as an RV on the move, or a boat leaving dock to go to sea) then you should DISABLE | + | Note that if you are leaving internet service coverage areas (such as an RV on the move, or a boat leaving dock to go to sea) then it is recommend to disable |
