venus-os:gx-gsm
venus-os:gx-gsm [2021-05-27 11:39] – guystewart | venus-os:gx-gsm [2021-05-27 21:24] – [3. Configuration] mvader | ||
Line 73: | Line 73: | ||
**Automatic recovery when disconnected** | **Automatic recovery when disconnected** | ||
- | When installing the GX GSM, or GX 4G LTE in an area that you expect | + | When installing the GX GSM, or GX 4G LTE in an area that you expect |
- | Enabling this setting will eliminate the need to manually | + | |
- | Note if you are leaving internet service coverage areas (such as an RV on the move, or a boat leaving dock to go to sea) then you should DISABLE | + | Note that if you are leaving internet service coverage areas (such as an RV on the move, or a boat leaving dock to go to sea) then it is recommend to disable |
