venus-os:gx-gsm
venus-os:gx-gsm [2020-01-18 11:23] – [7. Supported Frequencies (2G/3G)] mvader | venus-os:gx-gsm [2021-05-27 11:39] – guystewart | ||
Line 5: | Line 5: | ||
- | The GX GSM is an accessory for [[venus-os: | + | ==== 1.1 Product description ==== |
- | It requires a SIM card of the [[https:// | + | The GX GSM is an accessory for [[venus-os: |
+ | It requires a SIM card of the [[https:// | ||
See also the [[https:// | See also the [[https:// | ||
Line 15: | Line 17: | ||
{{youtube> | {{youtube> | ||
- | === Antennas and accessories === | + | ==== 1.2 Antennas and accessories |
GSM: A small indoor GSM antenna is included. As an option we also sell an outdoor GSM antenna: | GSM: A small indoor GSM antenna is included. As an option we also sell an outdoor GSM antenna: | ||
Line 25: | Line 27: | ||
* GSM900200100 - Active GPS Antenna for GX GSM | * GSM900200100 - Active GPS Antenna for GX GSM | ||
- | [[venus-os: | + | [[venus-os: |
- | ==== Compatibility ==== | + | ==== 1.3 Compatibility ==== |
The GX GSM can be used with any of the [[venus-os: | The GX GSM can be used with any of the [[venus-os: | ||
The GX GSM requires Venus OS v2.22 or newer to be installed on the GX Device. | The GX GSM requires Venus OS v2.22 or newer to be installed on the GX Device. | ||
- | The GX GSM only provides an internet connection for the [[venus-os: | + | ==== 1.4 When to use a mobile router instead ==== |
+ | The GX GSM provides an internet connection for the [[venus-os: | ||
For installations where more devices need internet, such as a yacht or RV, consider installing a mobile router instead. [[https:// | For installations where more devices need internet, such as a yacht or RV, consider installing a mobile router instead. [[https:// | ||
Line 67: | Line 70: | ||
+ | **Automatic recovery when disconnected** | ||
+ | When installing the GX GSM, or GX 4G LTE in an area that you expect continous internet coverage, you should enable the " | ||
+ | Enabling this setting will eliminate the need to manually power cycle the modem if required, as if it stops working for any reason, the GX will reboot and that should in most cases resolve the issue. | ||
+ | Note if you are leaving internet service coverage areas (such as an RV on the move, or a boat leaving dock to go to sea) then you should DISABLE this setting, so that your GX is not rebooting itself for no reason. | ||
Line 100: | Line 113: | ||
| SIM wrong | Type of SIM is not supported | | | SIM wrong | Type of SIM is not supported | | ||
- | [[http:// | + | [[http:// |
+ | ===== 6. Trouble shooting ===== | ||
There are many reasons for modem internet connection to not work. Carefully go through each step of this trouble shooting guide. Make sure to start at the first step. When asking for help, make sure to mention each step taken and the result. | There are many reasons for modem internet connection to not work. Carefully go through each step of this trouble shooting guide. Make sure to start at the first step. When asking for help, make sure to mention each step taken and the result. | ||
Line 120: | Line 134: | ||
+ | === What to do if the GX GSM is not staying connected? === | ||
+ | Enable the " | ||
===== 7. Supported Frequencies (2G/3G) ===== | ===== 7. Supported Frequencies (2G/3G) ===== | ||
- | GX GSM, part number GSM100100100: | + | ==== 7.1 Available models & their supported frequency bands ==== |
+ | GSM100100100 - GX GSM 900/2100: | ||
* 2G (GSM/ | * 2G (GSM/ | ||
* 3G (UMTS/ | * 3G (UMTS/ | ||
- | * The used module is a Simcom SIM5360E. | + | * The used GSM module is a Simcom SIM5360E. |
- | A second model is coming, expected in 2020 Q3, having below frequencies, | + | |
+ | GSM100200100 - GX GSM 850/ | ||
- | * This new product will be based on the Simcom SIM5360A. | + | * The used GSM module is the Simcom SIM5360A. |
+ | * Expected in first stock in 2020 Q3. And only short lived; since its successor, the GX LTE 4G, having 2G/3G and also 4G support is also coming soon. | ||
- | ==== Regional Coverage Information | + | ==== 7.2 Notes regarding regional coverage |
USA, Mexico, Canada and most of South America: 1900 MHz is the most common frequency for 3G, which is unsupported for the current version of GX GSM. But a second model is coming in 2020, see above. | USA, Mexico, Canada and most of South America: 1900 MHz is the most common frequency for 3G, which is unsupported for the current version of GX GSM. But a second model is coming in 2020, see above. | ||
Line 140: | Line 161: | ||
In case of uncertainty please double-check: | In case of uncertainty please double-check: | ||
===== 8. Technical Data ===== | ===== 8. Technical Data ===== | ||
