Both sides previous revisionPrevious revision | Next revisionBoth sides next revision |
venus-os:gx-gsm [2019-10-03 20:54] – Accessory section linked krenzke | venus-os:gx-gsm [2019-10-03 22:01] – Line break added to prevent clipping krenzke |
{{:venus-os:gsm-apn-config.png?direct&480|}} | {{:venus-os:gsm-apn-config.png?direct&480|}} |
===== 4. Status ===== | |
GSM modem status can be checked at a glance by looking at the status bar. | |
^ Icon ^ Details ^ | ===== 4. GPS ===== |
| {{:venus-os:gsm-status-signalstrength.png?nolink&27}} | GSM modem is connected to network, but not to the internet (no data connection). Either on purpose, because an ethernet or WiFi connection is available. | | |
| {{:venus-os:gsm-status-gsm-internet.png?nolink&48|}} | GSM modem is properly configured, the 3G/E/etc icon reflects that the GSM modem internet connection is in use. | | |
| {{:venus-os:gsm-status-gsm-plus-wifi.png?nolinkx&54|}} | WiFi is available and its internet connection is in use. WiFi has priority over GSM. | | |
| {{:venus-os:gsm-status-pin-required.png?nolink&27|}} | SIM PIN code is required. | | |
| {{:venus-os:gsm-status-roaming.png?nolink&27|}} | Roaming, only informative. To use internet connection while roaming it needs to be enabled in \\ Settings -> GSM modem -> Allow roaming. | | |
===== 5. GPS ===== | |
When the optional antenna is added; the position will be visible like this: | When the optional antenna is added; the position will be visible like this: |
Also the position is sent to the [[https://professional.victronenergy.com|VRM Portal]]. | Also the position is sent to the [[https://professional.victronenergy.com|VRM Portal]]. |
| ===== 5. Status ===== |
| ==== Status Bar ==== |
| | {{:venus-os:gsm-status-signalstrength.png?nolink&27}} | GSM modem is connected to network, but not to the internet (no data connection).\\ Either on purpose, because an ethernet or WiFi connection is available. | |
| ==== SIM Status ==== |
| ^ Status ^ Description ^ |
| | Ready | SIM card is installed properly and registered to the network | |
| | SIM not inserted | SIM card is missing or not inserted properly. SIM tray might hang out a little. | |
| | PIN required | SIM card requires 4 digit PIN for unlock. | |
| | PUK required | SIM is locked due to wrong PIN inputs. 8 digit PUK is required to release the lock state. | |
| | SIM failure | SIM does not respond - might be broken | |
| | SIM busy | SIM is in busy state | |
| | SIM wrong | Type of SIM is not supported | |
===== 6. Trouble shooting ===== | ===== 6. Trouble shooting ===== |
| 1 | Check power | Check that the blue LED is either lit continuous or blinking | | | 1 | Check power | Check that the blue LED is either lit continuous or blinking | |
| 2 | Check USB connection | The modem must be connected to USB, and visible in the Settings -> GSM modem menu | | | 2 | Check USB connection | The modem must be connected to USB, and visible in the Settings -> GSM modem menu | |
| 3 | Simcard status | Check the SIM Status in the menu, it must show "Ready". It will show "SIM not inserted", or "PIN required", or "PUK required" and more related errors when there is a problem. | | | 3 | Simcard status | Check the SIM Status in the menu, it must show "Ready". It will show "SIM not inserted", or "PIN required", or "PUK required" and more related errors when there is a problem. Please refer to the [[venus-os:gx-gsm#sim_status|SIM Status list]] for details. | |
| 4 | Signal strength | 1 bar minimum for VRM logging, 2 or 3 bars are necessary for a working remote console | | | 4 | Signal strength | 1 bar minimum for VRM logging, 2 or 3 bars are necessary for a working remote console | |
| 5 | Carrier registration | Check that a name of a Cellular provider is visible in the "Carrier" field. If it is not, check signal strength and otherwise contact your simcard provider and/or insert the simcard in a phone to double check its operation and subscription status. | | | 5 | Carrier registration | Check that a name of a Cellular provider is visible in the "Carrier" field. If it is not, check signal strength and otherwise contact your simcard provider and/or insert the simcard in a phone to double check its operation and subscription status. | |
| 6 | Internet connection | Verify that the Internet shows "Online". Reasons for the system to not go "Online" whilst properly registered on the Network are: 1) APN not configured, contact the network operator for details. 2) The network is a different one than the home network (ie. roaming), and the setting to permit Roaming is disabled. 3) Signal strength is strong enough to register on the network, but not to open the data connection to the internet. | | | 6 | Internet connection | Verify that the Internet shows "Online". Reasons for the system to not go "Online" whilst properly registered on the Network are:\\ 1) APN not configured, contact the network operator for details.\\ 2) The network is a different one than the home network (ie. roaming), and the setting to permit Roaming is disabled.\\ 3) Signal strength is strong enough to register on the network, but not to open the data connection to the internet. | |
| 7 | Connection to VRM Portal | Verify that the VRM Portal menu shows a recent last connection time. See Settings -> VRM Portal. For more details, see [[https://www.victronenergy.com/live/ccgx:start#trouble_shooting_data_logging|the VRM Connection troubleshooting chapter of the GX Manual]]. | | | 7 | Connection to VRM Portal | Verify that the VRM Portal menu shows a recent last connection time. See Settings -> VRM Portal. For more details, see [[https://www.victronenergy.com/live/ccgx:start#trouble_shooting_data_logging|the VRM Connection troubleshooting chapter of the GX Manual]]. | |
An outdoor antenna typically increases received signal by 15 dB to 25 dB. | An [[venus-os:gx-gsm#accessory_antennas|outdoor antenna]] typically increases received signal by 15 dB to 25 dB. |
Note that when the GX Device is already connected to Ethernet or WiFi, these have priority over the cellular connection. Even when the available Ethernet or WiFi connection does **not** have a good connection to the internet. There is **no** automatic detection in place which in such case switches over to the GX GSM. In more technical language: when the cellular data connection is active, it is configured with a high routing metric. This way, the Linux kernel prioritises Ethernet or Wifi when these are available. | Note that when the GX Device is already connected to Ethernet or WiFi, these have priority over the cellular connection. Even when the available Ethernet or WiFi connection does **not** have a good connection to the internet. There is **no** automatic detection in place which in such case switches over to the GX GSM. In more technical language: when the cellular data connection is active, it is configured with a high routing metric. This way, the Linux kernel prioritises Ethernet or Wifi when these are available. |
